Ko Propo VFS-1 ESC
#572
Originally posted by corallyman
e-mail sent, evertyhing o.k.?
Let me know if its viewable.
Yes, no problems with it. Thank you!
#573
do you drive a corally? tamiya? yokomo? how about an esc to match your pro4?
here are the newest rebadged version of the VFS-1 esc:
http://www.rczone.net/modules.php?na...rticle&sid=575
#574
#579
Anybody know where I can pick up some more of the standard shottki diodes?
#580
Originally posted by berger
Is it worth buying a hyperbooster and running it along side my single ulimate diode, or buying a dual diode instead. Cant get the VFS-1 stuff in the UK yet but i can get hyperboosters. Only planning to race stock with this car.
#581
Originally posted by Jamie Corrado
Thanks fot the info Hebiki, after reading alot of this thread I figured you would be the one to answer.
here's the link:
http://www.shopatron.com/index/166.0.1052.1057.0.0.0
#582
Hey i just wonder if the "27 turn" VFS-1 data on the KO website is for silver can or stock motor like Monster Stock?
so does anyone have any data suitable for silver can racing? Our local track is a outdoor, technical track and i'm running a HPI Pro4 with Sorex 28R tyres, silver can motor and 4.1 gear ratio:
I feel no difference when upgrading from a cheap ESC to VFS-1 and my lap time was the same (i tried both the preset VFS-1 settings , and the 27T tech setting on the KO website)
is it because i'm just using a silver can?
Thanks a lot.
Thanks a lot.
#583
The 27T setting from the KO site is for Stock motors like the monster stock yes. Ive not run a silver can so i cant help you there, i would guess you would want quite a low profile though. Try Hebikis 27T setup from a few pages back and tweak from there is my recomendation.
#584
Thanks a lot.
Thanks a lot.
#585
yellow15.... stay low on the freq. for mabuchi/silver car motors. but be careful with setting it too low, you'll toast your comm and brushes. (i know from experience.
) id say stay between 7-12... adjust according to comm wear and brush wear. also check your run time. you can go lower on the drive freq. for the entire throttle profile if you have more runtime.
So should i try something like
12
12
11
9
8
7
8
9
11
12
so i can have some good half throttle response?
To be honest, i have tried a few different settings but i can't really feel/measure any difference in performance..
maybe it's just me lack of "sensitivity" ?
