Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 04-20-2005, 05:38 AM
  #721
berger's Avatar
I think the single diode has the power of 4 schottkys and the double 8. I may be wrong though......... Do you have the settings adapator?
berger is offline
Old 04-20-2005, 01:38 PM
  #722
Can anyone post a profile for a really tight track for stock and 19t?
Much Thanx
Obsidian is offline
Old 04-20-2005, 02:13 PM
  #723
recently i have been racing on a really tight track under 6 secs laps. I started off with the stock profile from the KO site and lowered the frequency in the range where i needed it. I think from the origional i lowered the whole profile by 3 or 4 steps on each throttle step.
Dan Hughes is offline
Old 04-20-2005, 03:21 PM
  #724
TFR
TFR's Avatar
Just got done setting up my VFS-1, on the Helios after set up. Do you go back to the throttle trim and turn it up to 150% or do you just leave it at factory setting 100%?
TFR is offline
Old 04-20-2005, 09:58 PM
  #725
carkillaii's Avatar
What does the hyperboster do?
carkillaii is offline
Old 04-20-2005, 10:03 PM
  #726
Hebiki's Avatar
Trader Rating: 26 (100%+)
Dan.. dont be scared to take it all the way down so that your lowest drive frequency is at 1. with today's battery technology, runtime should be easy.
also.. in stock racing.. everyone cuts every run anyways.. so it's definitely an advantage
TFR... yes i crank mine back up to 150.
carkillaii: it acts as a diode so it'll protect your motor when you hit the brakes. it also helps with RPM, efficiency and brush wear.
if you guys were at the RCX show last year.. you would have seen the demonstration with two escs.. one with a hyperbooster. one without. there was a significant difference.
Hebiki is offline
Old 04-20-2005, 10:07 PM
  #727
Hebiki's Avatar
forgot two things.
1. its only for stock or 19T
2. its out of production/discontinued.
Hebiki is offline
Old 04-20-2005, 11:46 PM
  #728
dont worry it is at 1.
Old 04-21-2005, 01:11 AM
  #729
S-T-R-l-K-E-R's Avatar
no not at the moment but i have some comming in by the end of the month.
S-T-R-l-K-E-R is offline
Old 04-21-2005, 01:49 AM
  #730
Hebiki's Avatar
thats what im talking about!
Hebiki is offline
Old 04-25-2005, 10:46 PM
  #731
Hebiki's Avatar
Default New Math
hey guys.. here's your math lesson for the day!
full throttle + big metal dot + concrete wall = HURTING
ill let the pictures do the talking.
Hebiki is offline
Old 04-25-2005, 10:54 PM
  #732
Trinity2's Avatar
Post
Hebiki. Sorry to see like that
Trinity2 is offline
Old 04-25-2005, 10:55 PM
  #733
Hebiki's Avatar
thanks.. its all good tho. i had fun driving that night....too bad my wallet didnt have as much fun.
Robert Morris is gonna laugh when he sees this.
Hebiki is offline
Old 04-25-2005, 11:01 PM
  #734
Trinity2's Avatar
Post
Yeah. It`s not a life, you can buy another one.
I use that same esc in my Pro4 and i`m very please about it
Trinity2 is offline
Old 04-26-2005, 03:49 AM
  #735
Spud_J's Avatar
Default PC Interface lead
Not sure if anyone on here can help me.
Left the programming lead for the PC interface at the circuit last weekend, 200 miles away. Not my best idea!
I was wondering if anyone knew the pinout from the connector that plugs onto the receiver connector on the speedo to the serial connecor on the PC. I know its a pretty simple lead and I'm sure I could make one one up
Many thanks
Spud_J is offline
