USRCF1 Formula One national event! >
Old 04-05-2011, 11:33 AM
  #136
mxrich's Avatar
He has his ducks in a row for this car. And I stll don't know how he keeps his table so clean. I keep a snow shovel on standby before raceday.
mxrich is offline
Old 04-05-2011, 11:39 AM
  #137
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Well i just drove it around the street, kinda hard to really tell anything but it drives! bad news is somehow between taking my RS out of my buggy and installing it in my F1 it doesnt work anymore, thats the second damn RS in a mth that has gone bad, i have had it with Tekin.
With the 17.5 /2s and 3.25 ratio it is not near fast enough so im going to try 3s tomorrow and see how that goes, if i dont like it i will go to a hotter motor/2s. it has a cool sound to it though and seems to have plenty of steering ( on a dirty street), i think it will be a keeper!
MantisWorx is offline
Old 04-05-2011, 12:01 PM
  #138
snoopyrc's Avatar
I don't mean to be antagonistic to you, and I like the cut of the chassis and all of your work, but would I not be on par with you if I take an old F201 and take out the front drivetrain?
snoopyrc is offline
Old 04-05-2011, 12:15 PM
  #139
MantisWorx's Avatar
battery placement, motor placement , cant use the current f1 style because of the wheelbase/width and why chop up a f201 when i can easily make something better myself? if you take the shaft out of 201 it pushes like a plow, you cant make it turn. and besides where is the fun in that? not to mention there are no good tire choices for that format. if you take the front drivetrain out, the answer to your question is NO, you wont be anywhere near me!!
Old 04-06-2011, 09:38 AM
  #140
Default Silver Can
Have you tried running this chassis with a silver can? If so, how does it run? And a little silly question.......what do you call it?
jujubean is offline
Old 04-06-2011, 11:24 AM
  #141
MantisWorx's Avatar
no, im not a believer in the silver can! to me that like putting a bug engine in a top fuel dragster! im a realist and i like speed not only that but the gear ratio is fixed 3.25 and i dont think that is optimal for the silver can. i may try a 21.5 but only with boost and 3s. this is not a production chassis, i have no intention on making them to sale but of course money can always change that! once i get this one figured out i am going to make another one with better material mainly carbon. right now it is 60g heavier than my 104 that has a normal battery. on the street it drives really good much different than my 104.
Old 04-06-2011, 01:58 PM
  #142
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
I tend to agree with your analogy of the Silvercan.
But with this solder job it looks more like user error than an issue with the Tekin product ?
Motor (+) and (A) wires are a little too close for comfort.
RedBullFiXX is offline
Old 04-06-2011, 02:02 PM
  #143
MantisWorx's Avatar
they dont touch and solder does not move once its on, the picture is fuzzy so it looks closer than what it is. the speed controller comes on just not getting a motor tone. been at this awhile, not my first rodeo! if those two wires would have touched it would have smoked as soon as i squeezed the trigger, not the problem i was having. last race in my buggy it cut out a couple of times and last night upon inspection i noticed that the capacitor was broke, so maybe that caused the issue i dont know.
Old 04-06-2011, 02:14 PM
  #144
Pro10noob's Avatar
Try your sensor wiring and the cable from esc to reciever.
Had a problem like this also and it was the cable from the esc to reciever.
regards Roy
Pro10noob is offline
Old 04-06-2011, 04:27 PM
  #145
Capacitor sounds like the issue.
First "Rodeo" or not, those solder joints are funky
Good luck with it, hope you get it sorted out.
Old 04-06-2011, 05:16 PM
  #146
MantisWorx's Avatar
regards Roy
hmmmmm i will try that, never checked that cable ,its strange that it worked and nothing changed. im having a brain fart but when you hook up the hotwire you shouldnt have to turn on the ESC right? i was trying to program it before i installed it and i had to turn the switch on for it to connect? i changed the sensor wire out and nothing changed.
Old 04-06-2011, 05:23 PM
  #147
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
You do not need power to update the esc. The USB supplies the power. I update them straight out of the package with the rubber band and all frequently.
andrewdoherty is offline
Old 04-06-2011, 05:27 PM
  #148
MantisWorx's Avatar
thats what i thought(i have four different programmable ESC's i have been messing with!), well thats definately strange then, so that means that the power wire from the three wire cable must be bad or have a short in it and that would explain the random shut downs last week! im going to go check it now and see if i can find it! i sure need this RS to work, no time to send it back and have it fixed for the race. right now i have a hobbywing in it, andnon sensored is not good for off road
Old 04-06-2011, 05:30 PM
  #149
MantisWorx's Avatar
FYI we are having a pre race practice next weekend at Mikes for the locals. im hoping to get some video for you guys!
Old 04-06-2011, 05:33 PM
  #150
If its just the receiver wire, I can fix it for you when I come. You may not be able to wait that long though. I got some mad PCB soldering skillz. Inside the case the switch and receiver wires are doubled over and I have had them break at the board. It is much more likely that the wires are shorted at the receiver plug. The factory RS receiver plug is a little wimpy., I always just snip it and replace it right away when I do fresh installs because I am usually shortening the wire anyway.
