Thunder Power RC Z3R Motors >
Like Tree1Likes
Old 05-08-2014, 02:14 AM
  #616
Skiddins's Avatar
Originally Posted by Condor Speed
Any body can tell me what is the stock rotor size on the Thunder Power 13.5 motors? I can't find any info on the site.
Std is Red, 12.23mm in diameter.
Blue (Torque) is 12.23mm, but the magnetic material section is 1mm longer (usually slightly higher gauss than the Red)
Green (Hi-Torque) 12.43mm and the magnetic material is the same length as the Blue. Slightly higher gauss than the Blue, but it's the change in diameter that makes the difference.
Skiddins is offline
Old 05-22-2014, 11:21 PM
  #617
Originally Posted by Skiddins
Have you done any testing with boosted stock TC's yet, i.e. 10.5 & 13.5?
Originally Posted by edhchoe
I just got my Thunder Power 21.5t for my f1 and the sensor board won't turn.
I even loosened the three long screws also but the timing cap won't budge.
never mind…. got it to turn now..
Hey Ed how did you get it to turn? I bought this motor from you and it's stuck again
fx35rc is offline
Old 05-26-2014, 10:35 AM
  #618
KA2AEV's Avatar
I don't have that, I just Googled RC Bearing remover (I think)
Thanks Skid I'll try that, looks like a useful tool
KA2AEV is offline
Old 05-26-2014, 10:39 AM
  #619
KA2AEV's Avatar
I had the same problem when I got mine brand new, seems like the people who assembled these really tightened them down, all I did was loosen the three screws and then really
Grab it tight and give it a twist
KA2AEV is offline
Old 05-26-2014, 10:48 AM
  #620
Does anybody have any information about a new motor?
Awesoman is offline
Old 06-02-2014, 12:59 PM
  #621
[QUOTE=KA2AEV;13290083]I had the same problem when I got mine brand new, seems like the people who assembled these really tightened them down, all I did was loosen the three screws and then really
Grab it tight and give it a twist[/QUOT
Thanks.
fx35rc is offline
Old 06-14-2014, 07:03 PM
  #622
303slowdown's Avatar
Trader Rating: 24 (100%+)
I know the mod stators are sapose to use a different can than the stocks but I put a 5.0 stator in a 17.5 can and even though it has a little gap between the can I hooked it up and it seems to work fine. Can I keep running it or should I not ? Has anyone ran a mod stator in a stock can ? Thanks
303slowdown is offline
Old 06-22-2014, 04:40 AM
  #623
Hi guys
What ratio do you people run for 17.5 blinky?? In touring car. And how much endbell and rotor ??
________________
TC6.2 MUCHMORE FLETA PRO THUNDERPOWER 17.5 TURN
HITEC SPEKTRUM
onroad racer is offline
Old 06-22-2014, 04:58 AM
  #624
elee32's Avatar
Trader Rating: 18 (100%+)
Originally Posted by onroad racer
Hi guys
________________
HITEC SPEKTRUM
Start around 3.8. 35 degrees timing, green rotor.
elee32 is offline
Old 07-10-2014, 07:10 PM
  #625
hi guys, i need help for 10.5 Boost!
some questions about what I read.
I use the green rotor; High Torque.
I'm trying to FDR 6.23 (foam tires rollout 30)
EndBell 25 degrees.
temperature around 70C.
The track is fast, https://www.youtube.com/watch?v=OOzETAXicTk
It's a good start?
Green rotor setup this this ok? (boost max 40 +24).
Thank you for your attention.
314ck5h33p is offline
Old 07-11-2014, 01:27 AM
  #626
Skiddins's Avatar
EndBell 25 degrees.
It's a good start?
Perhaps gearing at around 7.0fdr?
Skiddins is offline
Old 07-11-2014, 09:36 AM
  #627
tks Skiddins.
In the last weekend, i try 7,08FDR, is no good, more hot, around 80 at 85 degrees in motor, and too my best laps higher.
Maybe have more torque, this setting was not good.
The endbell in 25degrees, is a try by try, start in 15, and up the temperature of the motor is allowing.
this is the way I'm going, I do not know if anyone has similar experience in these conditions, 10.5 + green rotor.
Old 07-11-2014, 05:17 PM
  #628
Skiddins's Avatar
tks Skiddins.
Maybe you could turn down the timing on the ESC.
Make sure you have a good fan on the motor.
Skiddins is offline
Old 09-05-2014, 12:04 PM
  #629
Hi,
I need advice running TC 10.5T blinky with standart rotor on a large outdoor track how much timing do I run and what is a good starting point for FDR ?
Thank's
Claude
toroloco is offline
Old 09-05-2014, 12:32 PM
  #630
G-rem's Avatar
Originally Posted by toroloco
Hi,
Thank's
Claude
I ran this configuration last year on my Awesomatix: 35° of motor timing (never go higher or the motor could burn), ratio of 4.46 (88/41 in 64 pitch) and 2 fans blowing on motor.
I never went higer than 80°C temp motor like this, even with air temp @ 28-30°C
You can a little change the ratio and go to 4.2 if needed.
Cheers,
G-rem
G-rem is offline
