Ofna Ultra GTP2e
#181
What kind of suspension does the gtp2e have in the rear ? and why is the pivot ball better ? Also it has shorter shocks then the gtp2e. Im running it on asphalt so it's prob best i just get the gtp2e ? Watcha think ? body doesnt really matter to me at first as i would prob. get something different down the line.
The shocks for the rear of the GTP2E are longer than the front. I'm guessing that the OVAL car uses 4 GTP2E front shocks all the way around.
#182
Super Moderator
pivot ball allows the ease of TOE adjustments. A simple turn of the allen wrench and you're done. To change toe on the GTP2E, you need to change the rear toe block or the uprights.
#184
No problem I think I may switch my order up now to the dirt oval but before i do , will the shorter shocks make the car lower bc I will mostly be running on the street ? Wouldn't this be a bad thing bc I'll be bottoming out? Also can you post a link of that body you are talking about bc I can't see the image. Someone also stated it has a offset motor mount , what does this mean and will it affect me running a larger pinion with a 2650kv motor for speed runs? Thankyou
#190
Hi guys,
This is for a very good friend.
He just bought a GTP2-E for 14.8v 4S class, he have 2 motors from Tekin a 2.050kv short Buggy style motor, and a 2.000kv long Truggy style motor, along with the RX8 ESC from Tekin.
He asked me to post here, in order to find out wich would be the best gearing for any of this 2 motors, for a medium size track.
thanks a lot,
thanks a lot,
#191
Hi guys,
thanks a lot,
thanks a lot,
#192
here is my new ofna gtp2e still a work in progress.
#194
Still trying to get my battle skills up so can I can compete with you guys.
#195
