Ofna Ultra GTP2e
#931
i just got rid of the receiver box completely
#932
Man this thing looks cool! I'm looking for my 1st onroad car and this seems to fit the bill..just looking into body choices are there a lot to chose from I like painting so thats half the fun for me ..does anybody know if some one makes a 2010 camaro body ? Or what bodys I should look for that also fit ,thanks
#933
#934
#937
Does anyone know an easy way to tighten the motor mount screws without removing the receiver box or using the wrench's small end to tighten the whole length of the screw? My man sized fingers are too big to hand tighten the screw.
That's the only problem I see with the vehicle.
i found out that if i'm slow and careful i can loosen and tighten the 2 screws just fine with it...
#940
Yes you need loctite, every set screw and every screw without a locking nut should have loctite,on setscrews for pinion,drive cups,I use red and just use the tip of my soldering iron to heat it up to loosen the set screw
#943
Steering
Ok, I had a chance to give the car some time on a track, albeit small track...
Does this car suffer in general from the lack of off power steering?
#944
Yes it does I run no sway bar in the front and stock black springs 35wt oil.
#945
So, red springs are no longer the setup?
