Tamiya TRF417
#1160
are you beating the Teacher M3 thats what I wants to know... and
are you beating up the James borthers also
#1161
Hello, just concerning setup between tracks, what are the main changes between going from carpet to asphalt ?
What should be the first thing changed or what does everyone tend to change?
I was looking at some setup sheets and I think that most people tend to run shocks more upright, thinner oil, higher roll centeron the inner pivot. And also the longer links .
Am I right ?
Am I right ?
Starting setup for asphalt is HPI Silvers all round, with 450wt oil, whilst indoors it would be Tamiya white/blue, with 500wt oil.
Otherwise, I tend to leave the rest of geometry alone until I get to the track and see what it needs altering.
An interesting point is that I actually tend to alter the roll centre more when changing class, rather than indoors or out. With higher wind motors, I'll tend to run a higher roll centre for more corner speed.
HiH
Ed
#1162
I am in the process of trying to decide which TRF car to purchase, a 416x or 417. I come to you with this question. Knowing what you know now, which car would you purchase, a slightly used TRF416x or a new TRF417? I have the opportunity to purchase a TRF416x with a bunch of spare parts for $140 less than a new TRF417 with a few spare parts. I have never raced on-road so I will have a learning curve with both cars. Would you go for the older car at a lesser price or a newer car with the newer technology?
Both cars use the same suspension components, so all the usual spares will be available for a while.
HiH
Ed
#1165
#1166
To be honest, whilst the 417 is the latest car (and I do believe is faster), you really can't go wrong with a used 416X. As you mention, your starting out in on-road, and the money you save on the 416 could be put towards other stuff (tyres?).
HiH
Ed
HiH
Ed
And just a quick question to anyone; the white/blue/yellow springs that come with the kit, are they white short or yellow short or blue short or just normal white ?
As the short version of the same spring are softer, so when I try and compare, I know which one im doing xD.
#1168
#1169
