Tamiya TRF417
#2057
Trader Rating: 171 (100%+)
Alex I'm not getting rid of my TRF...
#2059
I found the Tamiya not good on carpet, awful actually. Had to make considerable modification to get it to be equal to my Xray. Its a truly fast car but I have found it difficult to tune to be honest. I went the opposite way to convention and increased the flex dramatically and the car was amazing
#2060
#2061
#2062
R/C Tech Elite Member
What setup are you running...I posted one recently that works very well anywhere I go. The car works very well on carpet....
http://linewerx.com/Linewerx/Racing_...IIC%202011.pdf
Art's car looked super good... imagine if he could drive
#2063
#2064
My was worked well at iic and was easy to drive I just sucked
#2066
#2067
Update:
I tried some different driveshafts and even tried putting the rear driveshafts in the front, with no success at all.
I really don't know what is wrong, but this isn't just normal wheel-chatter. At the end of the straight at my home-track, we have a left sweeper. When I apply steering at the end of the straight, I can feel the car "jumping" (due to vibrations in the front) so it won't steer in properly and it won't brake.
I am about to give up. The car is un-driveable, and I can't figure out why. I wanted to buy the 417X, but that car is probably 2 months away (if we should believe the rumours).
Hi guys,
I hope some of you experts can help me a bit with my 417.
When applying 50+% steering, I get some weird grinding noices and a lot of vibrations. It is not the normal spool wheel chatter, but it is a lot more violent. The problem is also present with a geardiff.
I have changed steering knuckles, C-hubs, wheel hexes, wheel axles (51445), and probably more that I've forgotten. The problem is, as far as I can see, in the front, as I have tried removing the belt and turning the wheels by hand, without improvement. I have tried removing the dampers, and detaching the steering and the camber links. No improvements.
I recorded it, so you can see it yourself:
I hope someone knows about the problem, or can see it from the video. I have had 3 different Tamiya-drivers looking at my car, and no-one can find the problem.
+ YouTube Video | |
#2068
You can try one thing to eliminate that it is something in the drivetrain and not the spool.
Use a geardiff up front with cleaning putty in it.
It almost reacts like a spool but there is some movement in it so this should eliminate the chatter.
If not then you have a serious job finding what is wrong up front.
When did it start?
After clipping a boarding?
Was it always there?
Did you change something on the car and after that it occured?
I still think it is almost normall wheel chatter but i could be wrong.
It can also get worse when you run a lot of downstop so the springs can be loose between the spring collar and the spring retainer.
I would start with the geardiff up front and see how it goes.
regards Roy
When did it start?
regards Roy
Update:
#2069
Hi,
I have tried with a gear-diff with 500k oil.
Downstop has been checked, and we have even tried some extreme downstops (in both directions). We have also tried with the shocks detached.
I started on my 4th battery in this indoor season, between two outings. I didn't have a crash. I have just barely touched the inside of a corner on the curb a couple of times, but nothing serious.
When did it start?
regards Roy
When did it start?
regards Roy
#2070
Have you checked the screw, or the bearing, or anything close from the wheels ?
