Like Tree4Likes
Tamiya TRF417
Old 01-10-2011, 09:07 AM
  #556
Tron's Avatar
Trader Rating: 17 (100%+)
Originally Posted by M3dreamin2008
Is the kit set up the best way to go? I will run on extremely high traction indoor asphalt.
I don't run a 417, but I do favor a high traction indoor track.
I like to run Jilles basic rubber setup, with roll centers "higher" meaning inner camber link position with less spacers...this reduces traction roll.
The only other change I make is front and rear camber about -1.
Tron is offline
Old 01-10-2011, 09:15 AM
  #557
Approximately how much weight are people adding for the new 1380 weight rule? I know it depends on the electronics installed. I just want an average to determine how many lead weight packages I should order.
malkiy is offline
Old 01-10-2011, 09:35 AM
  #558
Well with my 416, I'm about 30 gms under, and my layout is similar to my 417, just haven't got it put together yet. That's with a rs pro, futaba rec, and 9550 servo.
shaggy1 is offline
Old 01-11-2011, 07:02 PM
  #559
So is it safe to say at this time there is no direct fit spur gears available for this car? I understand you can just drill to 3mm holes in other gears.
M3dreamin2008 is offline
Old 01-11-2011, 07:36 PM
  #560
I ordered some spurs thru speedtech the other day that are supposed to be designed for the car. Just haven't gotten them yet to give you a definate answer. I believe they were by RW.
shaggy1 is offline
Old 01-11-2011, 07:44 PM
  #561
ngo8's Avatar
i am building my 417 right now and i put on the xenon vss spurs and they are a direct fit.
ngo8 is offline
  #562
KHoff7's Avatar
I believe the new style xenon gears fit as well.
Edit: What he said ^
KHoff7 is offline
Old 01-11-2011, 08:51 PM
  #563
TryHard's Avatar
Any spur with a 4hole mounting will fit, which the Xenon's have too.
Kimborough, RW etc need the extra hole.
Personally, I just brought a stash of 113t Tamiya spurs...
TryHard is offline
Old 01-11-2011, 09:15 PM
  #564
syndr0me's Avatar
Trader Rating: 32 (100%+)
I know Tamiya's gears are supposed to be a different pitch, or whatever, but when I ran them with my 64P pinions, it was the quietest sedan I've ever had. What's the drawback to the stock gears?
syndr0me is offline
Old 01-11-2011, 09:34 PM
  #565
tommi's Avatar
Kawada spur gears fit perfectly.
tommi is offline
Old 01-11-2011, 10:58 PM
  #566
fullout's Avatar
Originally Posted by LOSI123
Anyone know of any stronger after market inner hinge pins for this car. I know dont crash etc... but they seem to bend more often than some other brand cars ive had given the same approximate speed of crash etc...
A friend runs hpi pins in his, i'm not sure the exact part # but muchhobby.com may have it listed as option part, i know that's who put my buddy on to them.
fullout is offline
Old 01-12-2011, 12:02 AM
  #567
Jack2's Avatar
there is no drawbacks! I'm running the factory 111t and I bought a bunch of spare 111's and a few more 113's. I agree also, very quiet, perfect mesh.
Jack2 is offline
Old 01-12-2011, 08:11 AM
  #568
2-Bad's Avatar
Trader Rating: 24 (100%+)
Can someone tell me the length of the front steering turnbuckles?
Thx....
2-Bad is offline
Old 01-12-2011, 08:46 AM
  #569
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Thx....
42mm
Tamiya # 54250
or these
#42120
http://trackstarrc.com/trackstar/ind...mart&Itemid=64
Racecrafter is offline
Old 01-12-2011, 09:52 AM
  #570
2-Bad's Avatar
Originally Posted by Racecrafter
42mm
#42120
Thx, thats them...
2-Bad is offline
