TAMIYA M-06 Thread >
TAMIYA M-06 Thread
Like Tree121Likes
TAMIYA M-06 Thread
Old 10-12-2018 | 06:21 PM
  #2191
Ha Ha!.....Thanks for the info guys. But; I know about all of that (I've posted my own set-up a few pages back. . . . .page 138 - post # 2068).
I just want to run this chassis more relaxed.
I think the Longest Wheelbase is the answer for Ending some Oversteer.
GuyIsDamGood is offline
Old 12-18-2018 | 07:39 AM
  #2192
StahlVille's Avatar
Hello guys!
Is there a Tamiya MChassi parts interchange chart somewhere?
StahlVille is offline
Old 12-18-2018 | 08:55 AM
  #2193
That.. might be a fun thing to get defined. Sadly, I only own a M05 and a M07, so I can't do a stare and compare.
M05/M06... I believe the arms, hubs, uprights, diffs, axles, gears, bearings, wheels, shocks, all interchange.
Nerobro is offline
Old 01-11-2019 | 08:41 PM
  #2194
My 2019 New Year resolution is this. To win the Tamiya Asia Cup (8 countries) with the M06. Have 7 months to get the speed.
Raman, PDR, ruebiracer and 1 others like this.
rccartips is offline
Old 01-11-2019 | 08:57 PM
  #2195
Raman's Avatar
You can do it!
perhaps we will have an M08 this year
Raman is offline
Old 01-12-2019 | 07:39 PM
  #2196
MaxRain's Avatar
https://youtu.be/PAMj-bmr1bE
One thing that I did with my M06 was place the ESC in the rear end of the battery tray and then place a shorty lipo in front of it. If you have chassis balance issues, put weight where you need it. Wheel base for this setup I think is mid, but could be long. The body I use is the mazda miata.
rccartips likes this.
MaxRain is offline
Old 01-13-2019 | 01:55 AM
  #2197
foampervert's Avatar
Default totally!
Originally Posted by Raman
You can do it!
Fingers crossed...
foampervert is offline
Old 01-13-2019 | 03:13 AM
  #2198
Re-read posts from 2011... can't believe it's almost a decade since M06 was released. Anyways, while I read setups, one thing missing is build quality tips. So here I go
Build quality + setup = speed
Old 01-13-2019 | 03:36 AM
  #2199
Default Thanks for the setups
I recently used a setup I found on rccartips... I think it was a setup for portia's car... Developed by yuichiro Tanaka... It was superb. Worked well with my s13 Silvia shell.
i did transfer the service and eac to the battery tray though.
Thanks for sharing!
Alexander
Old 01-14-2019 | 11:11 AM
  #2200
ruebiracer's Avatar
So cool that you give the M06 a go again Joel!
I´m with Raman, if anyone can do it, it´s you and Porsha! Thank you very much for your tutorial, really informative! Seems I know know, why I Always ended up on the innermost holes on my M06.
All the best for your preparations!
Greets from Germany to you and all the old M06 guys here, Matthias
ruebiracer is offline
Old 01-14-2019 | 12:25 PM
  #2201
https://youtu.be/VV5RL6TU-_M
You're my kinda dude. Doing actual math, and doing good comparisons. This.. is incredibly uncommon.
Nerobro is offline
Old 01-14-2019 | 04:33 PM
  #2202
Hi Matthias, Nice to here from you again. Is M06 still being raced in Germany? Porsha quit racing, so it's just me now. Yes, rear innermost gives most balanced movement with the stock front shock angle
So the headaches begin. First time out, was not even getting the car to go straight. Reasons 1) bad servo, not centering 2) front track wider than rear.
Because of that, hit something, destroyed the plastic steering linkage. Wanted to retire the M06 hahaha.
Fabricated a graphite steering plate from an old F103 fiberglass chassis. Now back to testing.
However the 8 year old plastics are disintegrating. Shock towers, steering linkage, servo holder, are just cracking to dust
Old 01-14-2019 | 04:49 PM
  #2203
At least you can buy the parts new still. And the car is still in new production.
.... I suspect we're going to hear about a M08 in febuary....
Nerobro is offline
Old 01-14-2019 | 11:17 PM
  #2204
Interesting... My m06 uses 6mm hexes in front and 4mm hexes in the rear... Handles really well.
Won't having a wide rear track cause the rear to lose grip?
​​​​​​alexander
Old 01-15-2019 | 03:14 AM
  #2205
​​​​​​alexander
Did a lot of track width testing today. For my car, the end that is wider has more lateral grip. Which sounds good to me as it aligns with theory, wider has less lateral weight transfer = more grip from both tires.
Especially on-power from mid corner to exit. If rear is wider I can catch the slide. If narrower, sudden spinout.
Yours might work well depending on other areas (e.g. camber, toe, etc). Mine was at zero camber all around, 2deg toe rear, 0deg toe front. M-grip tires all around.
Maybe you used a front tire with less grip than the rear?
