Like Tree69Likes
TAMIYA M-06 Thread
Old 04-14-2018, 05:51 PM
  #2176
Raman's Avatar
Trader Rating: 60 (100%+)
Well itís May and last year Tamiya released the M07.. was hoping for an M08.. instead they released a TB05
Raman is offline
Old 05-11-2018, 06:51 AM
  #2177
Hi, Does Renault 5 Turbo fit M06, I 've found the body from TeamBlueGroove.
Pao44445 is offline
Old 05-11-2018, 06:56 AM
  #2178
Raman's Avatar
no it wonít fit.. there isnít enough room in the back
Raman is offline
Old 05-11-2018, 09:15 AM
  #2179
Dan
Dan's Avatar
Trader Rating: 54 (100%+)
Is an M06 or M07 faster on black carpet?
Dan is offline
Old 05-11-2018, 09:20 AM
  #2180
Raman's Avatar
I missed TCS this year so have yet to go against an M07. The 06 will still accelerate quicker.. quesiton is corner speed.
The 07 does have better suspension geometry, so that will probably play a factor.
Raman is offline
Old 07-10-2018, 10:06 AM
  #2181
Hi all, I'm new to the M06 thread. I have an ABC MR2 AW11 body that I'd like to fit to a chassis. I have the HPI Cup Racer chassis, which fits nicely, but is a very open design. I'm looking for something more enclosed and protected. The M06 has the right wheelbase (210 mm) but I am not sure about the track width. The body is 160 mm wide. Is the track width adjustable on the M06? I like the wheels on the Renault Alpine kit but the specs say the width is 168 mm. Are there adjustments in the chassis for track width, or is it done with different wheel offsets? Thanks!
Falesi is offline
Old 07-11-2018, 05:51 PM
  #2182
Raman's Avatar
No you canít adjust the track width. So either you use hex axles that are wider or wheels with + offsets
Raman is offline
Old 10-04-2018, 11:10 AM
  #2183
This chassis is give'n me a hard time.
I can't go fast into any Hair-Pin. (tap the breaks and it Over-Steers)
It Over-Steers less than before; with the set-up change; but it still has Over-Steer under (near) heavy breaking.
GuyIsDamGood is offline
Old 10-04-2018, 12:33 PM
  #2184
Raman's Avatar
Your main issue is that youíre trying to use brakes. You canít with this chassis. Itís a rear wheel drive RC chassis and will swap ends every time. Especially in a turn. The only time you can use brakes would be on carpet when going perfectly straight.
My recommendation would be to practice letting off the throttle before entering the turn and applying throttle middle of apex. Get used to driving it that way and then you can even let off before entering and once you enter hop right back on throttle. It prefers to be driven that way.
Now if if you still feel you need brakes.. turn on drag brake on your esc.. that will work.. but I personally feel it will rob you of corner speed.
Raman is offline
Old 10-07-2018, 08:10 AM
  #2185
It Over-Steers less than before the set-up change; but it still has Over-Steer under (near) heavy breaking.
Tighten the diff and you can brake. It also helps to have downforce. I guess you do not run a wing as you run the stock tamiya body of some sort. What diff do you run? open?
MatsNorway is offline
Old 10-10-2018, 10:11 AM
  #2186
Thanks for the info Raman.
Ha Ha!.....I agree. I want to drive this chassis more like a chassis with a rear And Front diff. I know.
I thought a set-up change would make a difference.
Thanks for the info MatsNorway.
I run an Open Diff (with some Anti-Wear Grease inside).
-I run the chassis with the Tamiya S15 Nissan Silvia Body.
Old 10-10-2018, 12:56 PM
  #2187
Get an oil diff. It is the single biggest upgrade you can do in terms of transforming the handling. Try it with tick oil to really notice the difference.
Old 10-10-2018, 06:55 PM
  #2188
Raman's Avatar
The trick to this car is weight transfer. You need it to be on to rear 90% of the time. This is why I suggest putting spacers in front shocks to take out all droop and allowing the rear to have full droop.
You need to change the stock diff! Its junk for the track. What surface are you running on? Carpet or Asphalt?
I run the ball diff very tight.. as I run on high grip carpet. When I ran on asphalt a few years back, it was still on the tight side.
i personally never ran the oil diff as my car was set up for TCS legality. Otherwise an oil diff would be a good option.
On low grip asphalt I would try 3k. On high grip carpet.. I would start at 5k and maybe even 7k!
MatsNorway likes this.
Raman is offline
Old 10-10-2018, 07:10 PM
  #2189
foampervert's Avatar
Default things you can try for m06
These things help with the oversteer that is inherent in m06
-use less grippy tires in front (vs the back). a grip differential will immediately make the car understeer, by how much depends on the difference in grip.
-Use long wheelbase. Long wheelbase cars have less inherent weight transfer off throttle and will reduce oversteer situations
-Use as little droop (maybe even zero) in the rear. again, this limits rear to front weight transfer when braking.
-drive with less brakes. less brakes means less weight transfer... try lowering (not neutral) the throttle before you come to the turn and smoothly increasing the throttle as you transition from turn entrance to turn exit.... obviously needs practice because no other car is driven this way... except for 2wd buggies long ago with crap tires...
-battery as forward as possible. this limits weight transfer to the front on braking... the weight is already in front. (i use super shorties in my m06, all the way in front, for this reason)
-make the rear roll more. softer rear springs and damper oil + lower roll centre
-make sure that the chassis is not scrubbing. this causes weird handling through the turn.
Do note that these tips are all within this thread and are by no means my own personal opinion. just a combined tuning advice from all users in this thread.
setup different AND drive different... or buy a m07
-Alexander
Raman likes this.
foampervert is offline
Old 10-12-2018, 07:21 PM
  #2190
Ha Ha!.....Thanks for the info guys. But; I know about all of that (I've posted my own set-up a few pages back. . . . .page 138 - post # 2068).
I just want to run this chassis more relaxed.
I think the Longest Wheelbase is the answer for Ending some Oversteer.
