Like Tree53Likes
TAMIYA M-06 Thread
Old 01-28-2018, 07:42 PM
  #2161
Raman's Avatar
Trader Rating: 60 (100%+)
Weight is being transferred on and off power. Since this is a rwd car, when you let off the throttle, you don't want the weight to go front wheels.. if it does, the rear will lose traction.. that's why you need no droop in front and lots of droop in the rear (corrected)
Raman is offline
Old 01-28-2018, 08:04 PM
  #2162
Super Moderator
nexxus's Avatar
Trader Rating: 309 (100%+)
Are you sure? I thought front droop transferred weight to the back on power, rear droop transfers weight to the front off power. So I would want no rear droop and lots of front droop?
You're telling me the opposite?
nexxus is offline
Old 01-28-2018, 09:42 PM
  #2163
foampervert's Avatar
You are right, there should be maximum front droop (weight can transfer back upon acceleration, for on power understeer. You can tune this out if you're a fast wheeler).
And there should be minimal rear droop so that weight doesn't transfer forward when you're braking.
foampervert is offline
Old 01-29-2018, 08:37 PM
  #2164
Raman's Avatar
Sorry about that.. I had my add / remove droop backwards.
Basically when you pick up the front, the suspension should not go down bellow your ride hide setting .. eg lots of droop
When you pick up the rear, your suspension should go down plenty .. no droop
Raman is offline
Old 01-30-2018, 05:44 AM
  #2165
howardcano's Avatar
Trader Rating: 37 (100%+)
Now you've got it backwards. Lots of droop = suspension drops a bunch when the chassis is lifted.
howardcano is offline
Old 01-30-2018, 10:25 AM
  #2166
Raman's Avatar
Clearly I have difficulties describing droop lol. That's what I thought.. when the suspension drops a lot it is drooping.
But then you hear that the track increase your droop by half a turn in the front, decrease your droop etc. If you turn the droop screw half a turn clock wise, you reduce the suspensions down play motion lol.
Raman is offline
Old 02-13-2018, 04:26 PM
  #2167
The Big Wig's Avatar
Anyone running these cars with big wheels? Boxter/S2000/Z3 style? What Tire combos do U use?
The Big Wig is offline
Old 04-03-2018, 08:42 AM
  #2168
Anyone tried a spool (seeing it seems to work for 1/12th) ?
rccartips is offline
Old 04-03-2018, 08:49 AM
  #2169
It worked in endurance racing... (full scale that is)
Nerobro is offline
Old 04-03-2018, 09:13 AM
  #2170
Porsche 956
Old 04-03-2018, 10:00 AM
  #2171
howardcano's Avatar
I once raced an HP Austin Healey Sprite with a locked differential.
Nerobro likes this.
Old 04-03-2018, 04:48 PM
  #2172
Thanks for the input guys, will try the M06 spool this weekend
Old 04-11-2018, 03:19 AM
  #2173
Default LESS Oversteer
To limit the Oversteer on this chassis:
-use the Longest Wheelbase
-set-up the least Droop in the Rear
-use 50 to 55-weight Shock Fluid in the Rear
-Soft(Red) Spring in the Rear
-2-Hole Shock Piston in the Rear
-1st Hole in Rear Shock Tower
-30 to 40-weight Shock Fluid in the Front
-Hard(Blue) Spring in the Front
-3-Hole Shock Piston in the Front
-4th Hole in Front Shock Tower
-place battery in the Rear
GuyIsDamGood is offline
Old 04-11-2018, 09:46 PM
  #2174
MaxRain's Avatar
For those who are interested, raced against M03's and M05's, I qualified 4th with my M06. Was fun trying to catch these guys. My M06 weight wise was much more the the first three cars, which probably was a disadvantage, but the car handled great.
kwkride likes this.
MaxRain is offline
Old 04-13-2018, 03:51 AM
  #2175
Hey MaxRain; looks like fun. Hope you had fun. . .good job.
