Team Associated TC6 Thread >
Like Tree20Likes
Old 01-10-2013, 10:13 AM
  #8566
Originally Posted by Rick Hohwart
You don't really need to make any modifications and it will be very competitive out of the box. Depending on the tracks you race on, adding a gear diff to the front might be a good modification. Some additional springs are always good to have on hand.
RSD DCJs are good if you use the spool. But even though they prevent some front end chatter, I don't believe this translates to faster lap times.
Rick, what tracks would you recommend trying a front gear diff ?
jha07 is offline
Old 01-10-2013, 01:04 PM
  #8567
bertottius's Avatar
Trader Rating: 28 (100%+)
I changed to a gear diff for VTA and it was awesome! Very good feel in and out of the turns. It's a fairly tight carpet track.
bertottius is online now
Old 01-11-2013, 03:18 AM
  #8568
I run a locked front gear diff after further inspection on my second hand tc6.1 bargain
Is it worth getting the double cardan unis because there is virtually no chatter i run 21.5 blinky so not fairly fast but am planning to start the boost soon is it worth the cash?
AleD123 is offline
Old 01-11-2013, 05:01 AM
  #8569
adriang79's Avatar
Well my e clips failed to arrive in time. I found a washer to do the job, but before I installed it I decided to have another look for the one that went flying, surprisingly I actually found it!
First race day with my TC6.1 FT tomorrow, fingers crossed for a good day.
adriang79 is offline
Old 01-12-2013, 09:34 AM
  #8570
07Forester's Avatar
Trader Rating: 10 (92%+)
Anyone have a good list of spares to keep around for the wc?
07Forester is offline
Old 01-12-2013, 10:26 AM
  #8571
DARKSIDE's Avatar
The only thing Ive broken on my WC is c-hubs, and steering rack...1 each
DARKSIDE is offline
Old 01-12-2013, 02:20 PM
  #8572
98NYFINESTVETTE's Avatar
Was that from a hit or weak parts?
98NYFINESTVETTE is offline
Old 01-12-2013, 03:49 PM
  #8573
KC10Chief's Avatar
The only thing I've broken is one of my shock bushings and that was from over tightening a screw.
KC10Chief is offline
Old 01-14-2013, 12:45 AM
  #8574
Hey Guys
I have a TC6.1 and a TC6.1 WC can anyone give me some tips in general to be faster
_________________________________________________
TC6.1 LRP 21.5 TURN TEKIN ESC
SPECTRUM DX3R PRO
TC6.1 WC REEDY 21.5 TURN
onroad racer is offline
Old 01-14-2013, 01:03 AM
  #8575
and will one of these fit without modification to the tc6.1 chassis
Old 01-14-2013, 01:22 AM
  #8576
evochick's Avatar
Originally Posted by onroad racer
Hey Guys
SPECTRUM DX3R PRO
Ok I can see your running 21.5. The trick with 21.5 (well all racing really) is to carry as much corner speed as possible. So your not wasting time slowing down. Simple really.
Reflex racing springs are a good start.
My tip from a pro this week. (not me) . If your grip is up go a harder spring all round it will help the car change direction quicker.
Beth
evochick is offline
Old 01-14-2013, 12:42 PM
  #8577
JustWill75's Avatar
Default Which is which?
Is this the correct Reedy17.5 motor?
this what I have in my TC6.1
This what I see on the page.
Was there a running change? How do I measure the timing per notch? I bought it second hand from another racer recently.
JustWill75 is offline
Old 01-14-2013, 01:12 PM
  #8578
Yes, the motor was changed. You have the original version.
jha07 is offline
Old 01-14-2013, 01:37 PM
  #8579
JustWill75's Avatar
Any differences? And how do you measure the timing? How many degrees is each notch?
Old 01-14-2013, 01:47 PM
  #8580
rangerjkb's Avatar
Trader Rating: 45 (100%+)
I believe original Reedy version has a slightly smaller diameter rotor, still very quick. One of the local AE drivers gears 46 Pinion/96 Spur/45* Timming for a small tight track. On the new version #956 rotor, I have used 48/96 with 50* timing with good success on similar track.
+1 on recommended on hand spares: C-Hubs, Blades, and front Spool Cups, but overall very durable.
rangerjkb is offline
