Team Associated TC6 Thread >
Like Tree20Likes
Old 12-13-2012, 12:15 AM
  #8311
YoDog's Avatar
Trader Rating: 28 (100%+)
Originally Posted by Vostok 7
I don't think there's a way that it could be done without drilling.
I'd be interested in someone proving me wrong though
There's already holes in the chassis in the middle, they just don't line up with the mounts that are currently available.
I have one that I got from eBay that is for a tamiya and was able to use one of the original holes and had to drill the other. I think it can be done but. I'll have to look at my chassis tomorrow.
YoDog is offline
Old 12-13-2012, 06:27 AM
  #8312
Hi!
What to do with tc6.1 c-hubs crazy slope????
I just put before race small 3mm screw from pinion and it delete that badly slop..
But that slop back now in badly big value again ...
AE made crap in that place
So there is option to use better C-HUB with bigger hole for double joints shafts at front????????? From another car?
M.Abramowicz is offline
Old 12-13-2012, 08:46 AM
  #8313
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
Originally Posted by YoDog
So... Would it be accurate to say there is a market for a direct fit, floating servo mount for the TC6?
Perhaps I will work something up that folks would be interested in. I like the 3 piece design like the Xray.
Sign me up! Im looking at another car too, by the way if you know anyone with a tc6 for sale let me know. Just the tc6 not the .1
Mr.juarez is offline
Old 12-13-2012, 09:28 AM
  #8314
DesertRat's Avatar
Would a bit of front kick-up and some rear pro-squat give you more rear bite? Right now I'm at zero pin angle at both ends.
DesertRat is offline
Old 12-13-2012, 09:57 AM
  #8315
CristianTabush's Avatar
More rear toe would be a more adequate solution.
CristianTabush is offline
Old 12-13-2012, 10:02 AM
  #8316
DesertRat's Avatar
I have as much rear toe as I can put in the chassis.
Old 12-13-2012, 10:05 AM
  #8317
wtcc's Avatar
Originally Posted by M.Abramowicz
Hi!
Unfortunately you are right
Also these things break if you just look at them, because of a wrong calculated tool... I really think about using alu c-hubs. Right now I use my old tc5&6 spare parts.
wtcc is offline
Old 12-13-2012, 11:08 AM
  #8318
Are you looking for more rear grip off-power, or on-power, or both?
jha07 is offline
Old 12-13-2012, 11:20 AM
  #8319
geeunit1014's Avatar
Trader Rating: 14 (100%+)
Hi!
I like running the old c hubs. just dremel them out to fit a DCJ.
I run up to 3mm of toe (3mm difference between the arm mounts, like 3.7*).. Add more rear camber or camber gain. If your at both of those already, take some front camber or camber gain out. It would be more helpful to see the rest of your setup to help
geeunit1014 is offline
Old 12-13-2012, 11:52 AM
  #8320
DesertRat's Avatar
The car is lose at high-speed turn-in, while accelerating out of the corner, and on changing directions despite the entire setup being geared for rear traction.
Old 12-13-2012, 12:25 PM
  #8321
wtcc's Avatar
Can you please post your actual setup and the kind of surface you are running on.
I for myself only know this car with a good rear and if it was to loose it was always easy to cure for example with 0.5° more camber or a little softer springs or a harder anti roll bar in front.
Only once on a low grip carpet I had problems to catch the rear into the corner and out of it with a spool in front. I then changed to a geardiff with 3000cst and the car was a dream since then (at least until the grip came up...).
wtcc is offline
Old 12-13-2012, 01:08 PM
  #8322
It easy to over do an adjustment and make the situation worse. For example, a soft rear suspension is suppose to help increase rear grip, but if you over do it, it can make the back end loose when changing directions. It can also cause the rear inside tires to lift slightly in mid corner because there is so much grip, and when this happens, the back end can snap loose.
Without knowing what your current setup is, or seeing the car in action, it's hard to know what you need.
Less front toe out, if you have toe out, would help decrease turn in.
Lighter rear diff oil can help with better grip out of corners, but will also give more turn in.
Loose changing directions usually means the rear is too soft.
jha07 is offline
Old 12-13-2012, 01:24 PM
  #8323
DesertRat's Avatar
My setup is such
Rear: 35wt shock oil, Green (12 pound, softest) spring, far inner hole on the tower and the arm, soft swaybar (white? Whichever is kit-stock), zero dot standard front arm mount, offset zero dot rear, 1-degree rear hub inserts, 3.5 degrees total rear toe, 2 degrees of camber, camber link in the inner top corner on the shock tower (no vertical mounts, just the carbon tower) with a 1mm spacer under the outer mount, 40wt oil in the diff, 5mm ride height, approx. 2mm of droop. Sweep EXP30 Kitty Rug tires with Paragon traction compound full sauce, diff at low in the chassis as it will get.
Front: 50wt shock oil, Gold (19.5 pound) front spring, zero toe, third-to-inner mount on the tower, outermost mount on the arm, yellow swaybar (again, kit stock, harder than the rear), spool, two degrees of camber, middle inner camber link position, two degree caster inserts, offset 2-dot mounts front and rear in the B hole (I think, I’m doing this from memory), 1.5mm of droop (the spring won’t allow much more), 5mm of ride height, diff in the middle high position. Half sauce on the front tires.
I run a 17.5 motor at 4.0:1 gearing, the car has decent balance and all of the screws holding the top-deck stiffness are in place.
I run on low-grip dusty carpet, the car is adamantly terrible, and the kit-stock setup with silver springs front and rear without the massive toe in was undriveable. It is getting better with each change I make to force the car into rear grip, but I don’t know how to add kickup or dive, squat or anti-squat in the process.
Is the car just a lemon or should I keep fighting? I'm not totally clueless, I know the car should have rear grip at some point, I've checked chassis tweak and every moving part on the car moves free in every dimension, but I'm at a loss here.
Old 12-13-2012, 02:22 PM
  #8324
My setup is such
Rear: 35wt shock oil, Green (12 pound, softest) spring, far inner hole on the tower and the arm stand your rear shocks up to the 3rd hole on the tower, and the middle hole on the arm, soft swaybar (white? Whichever is kit-stock), zero dot standard front arm mount, offset zero dot rear, 1-degree rear hub inserts change this to 0, 3.5 degrees total rear toe add shims so you get back to 3.5 toe with 0* hubs. should be able to use a 1mm shim on the front block and a 2mm shim on the rear offset block, 2 degrees of camber, camber link in the inner top corner on the shock tower (no vertical mounts, just the carbon tower) with a 1mm spacer under the outer mountchange to as much as you cen get under the wheel. should be able to get 2.5mm with a tall BS, 40wt oil in the diff, 5mm ride height, approx. 2mm of droop. Sweep EXP30 Kitty Rug tires with Paragon traction compound full sauce, diff at low in the chassis as it will getmid low.
Front: 50wt shock oil, Gold (19.5 pound) front springAE silver, zero toe0.5* out, third-to-inner mount on the tower, outermost mount on the arm, yellow swaybar (again, kit stock, harder than the rear), spool, two degrees of camber1.5 front camber, middle inner camber link positionposition 1 on the tower, two degree caster inserts, offset 2-dot mounts front and rear in the B hole (I think, I’m doing this from memory)go to 0B OS, with a 1mm shim all around, 1.5mm of droop (the spring won’t allow much more), 5mm of ride height, diff in the middle high positionmid low. Half sauce on the front tires.
I run a 17.5 motor at 4.0:1 gearing, the car has decent balance and all of the screws holding the top-deck stiffness are in place take the 2 screws out of the layshaft bulkheads.
Your setup is a lot different than what most of us would run. My suggested changed is red above. It seems like the rear of your car is extremely soft, which will let the car dump over in corners and become very loose. The front of the car is extremely stiff, which is probably an adjustment for the rear, but it just makes the front end wash out probably. Those changes should get you more in the ballpark of how I know the car likes a setup on carpet.
Old 12-13-2012, 02:36 PM
  #8325
My setup is such
First off, this car is no lemon.
My opinion is, your front springs are too stiff, which is why you have too much high speed turn in. Go back to the stock silver springs. Also, try 4 degree caster insert.
You also need to stiffen up the rear a bit, I also use green springs, but I use the yellow sway bar.
Are you using the A or B hole for the rear suspension mounts?
What pistons are you running front and back?
jha07 is offline
