Team Associated TC6 Thread >
Like Tree20Likes
Old 12-10-2012, 10:37 PM
  #8296
YoDog's Avatar
Trader Rating: 28 (100%+)
Originally Posted by beyondthepack
Hey guys, any idea on how to hook up your belcrank to a floating servo mount?
What???
Do you mean connect the steering bell crank to the servo that is mounted using a floating mount?
Remove the screw that holds the Ackerman adjuster and replace it with a pillow ball. You can find some details a few pages back with pictures. It's easy.
YoDog is offline
Old 12-11-2012, 02:03 AM
  #8297
evochick's Avatar
I have finally had time to install a WC chassis and install the xray T4 floating servo mount.
Really easy to do, it feels very solid and wont budge with the extra key hole on the mount to the chassis,
With the WC chassis the servo has lots of overhang
cant wait to give it a try
Extra info, i used a 10mm long ball in the bell crank, and put a nut on the other end to give it that little extra security
Beth
evochick is offline
Old 12-11-2012, 02:40 AM
  #8298
Monsta's Avatar
Hi beth,
Looks like we're running very similar setups.
Is there any tips you can give regarding xerun v3 setup with the sonic? I'll be running 17.5 boosted
Thanks!
Monsta is offline
Old 12-11-2012, 04:39 AM
  #8299
evochick's Avatar
Originally Posted by Monsta
Hi beth,
Thanks!
Sorry im no help there. I have only ever ran 21.5 blinky and 5t mod.
Beth
evochick is offline
Old 12-11-2012, 05:25 AM
  #8300
evochick - does that servo mod require any drilling to the chassis?
Johnnytc3 is offline
Old 12-11-2012, 06:06 AM
  #8301
beyondthepack's Avatar
Originally Posted by YoDog
What???
Thanks . Read a ways back, couldnt find the pictures, but description is good enough. Almost done. Waiting for Zeppin hubs, the ill post some pics.
beyondthepack is offline
Old 12-11-2012, 10:19 AM
  #8302
Beth
Looks nice, how much did this conversion cost you?
jha07 is offline
Old 12-11-2012, 02:07 PM
  #8303
evochick's Avatar
Yes, it requires 3 holes drilled, you use the carbon servo holder as the template, im hopeless when trying to measure and drill things accurately, this way you cant stuff it up.
Stupidly expensive, Xray parts are not cheap, but i liked this mount. Parts used are ( a-main prices)
XRA306201 XRAY Long Aluminum Servo Mount $6.99
XRA306230 XRAY 2.5mm Graphite Servo Holder $20.49
XRA306202 XRAY Central Aluminum Servo Mount $23.99
3RAC-TR328 3 Racing 28mm titanium turnbuckle $10
ASC 31285 Associated 10mm long ball stud $9.25 (i already had these)
Beth.
evochick is offline
Old 12-11-2012, 03:51 PM
  #8304
Professor's Avatar
beth the photon one would probably do the same job & would have been a lot cheaper than the xray part
Professor is offline
Old 12-11-2012, 04:29 PM
  #8305
I've heard the Yokomo BD-7 one works too, but it might be just as expensive as the Xray one
Vostok 7 is offline
Old 12-11-2012, 05:05 PM
  #8306
I used this one
http://www.rc-mushroom.com/product_i...a-post-p-25486
its even blue!!
ed
Edwin Pibal is offline
Old 12-12-2012, 11:18 AM
  #8307
Originally Posted by Edwin Pibal
Can you put a pic up with it installed on your car? Thanks.
jha07 is offline
Old 12-12-2012, 06:46 PM
  #8308
Trader Rating: 32 (100%+)
I have seen many guys did the centre servo mount thing (or floating servo mount).
From what I have seen, as long as the aluminium mount in the chassis centre is not more than 5mm thick, you are ok.
Anything more than 5mm, the front belt will def rub it.
hobbs is offline
Old 12-12-2012, 10:34 PM
  #8309
YoDog's Avatar
So... Would it be accurate to say there is a market for a direct fit, floating servo mount for the TC6?
Perhaps I will work something up that folks would be interested in. I like the 3 piece design like the Xray.
YoDog is offline
Old 12-12-2012, 11:06 PM
  #8310
I don't think there's a way that it could be done without drilling.
I'd be interested in someone proving me wrong though
Vostok 7 is offline
