Team Associated TC6 Thread
#7201
What FDR are you guys using with your silver cans?
#7202
I did that with Kyosho washers, but I didn't have a good feeling about it. I also didn't really like the back of the motor hanging 1 inch pass the chassis edge.
Now that's seems ok so it has more even contact all the way around? Do you know for a fact the center Opening is big enough for the front bushing?
#7203
#7204
Trader Rating: 27 (100%+)
So I got to break in my tek6 today and it is going to require some more tweaking but it is very easy to drive and to me that is a promising sign. Unfortunately I could not do a direct comparison as I ahd hoped as the layout was changed a few days ago so the carpet has not grooved up yet. Oh and I weighed the car and I was 1401g Im happy with that.
#7206
How much weigh 6.1 box stock?
#7207
#7208
i'm also going to complete the exotech conversion, to be used with a 13.5 motor, could you pls share with me your set up?
Ciao
Max
#7210
New needing a ton of advice.
Just was given a TC6, well sort of...Anyway I have a 17.5 Motor. The recommendation from Dual sky is 4:1 for touring cars 4.3:1 for a long track. my spur is 80t 48p. Am I correct to start with a 20t Pinion? I'm a fan of asking for advice over blowing money! Thanks in advance!
Last edited by Greenskeeper; 07-30-2012 at 09:17 AM. Reason: long track ratio was mis typed.
#7211
Switch to 64 will be easier to achieve the right fdr. 94 and 45 put me at 4.1
#7212
Just was given a TC6, well sort of...Anyway I have a 17.5 Motor. The recommendation from Dual sky is 4:1 for touring cars 4:3 for a long track. my spur is 80t 48p. Am I correct to start with a 20t Pinion? I'm a fan of asking for advice over blowing money! Thanks in advance!
#7213
#7214
So glad i asked!!!! I had wanted to run the 64p, but the parking lot we race in is not as smooth as I would like! It also came with the 80t and 87t 48p.
#7215
