Team Associated TC6 Thread
#5581
Thanks all.
Centering servo and place a horn 90deg were done and have been like that since I built TC6.
Steering has been adjusted by EPA and Trim and I have been happy
But since I am so OTAKU and start to look for some inperfections and am confused.
When steering angle are equal right to left, should servo horn travel right to left be equal as well?
When X=Y, should n=m like n:m=x:y ? otherwise steering angle is equal right to left but travel time could differ right to left in steering.
I probably should shut and practice but am quite busy n hard to find time to hit track so I have more time poking my car on desk
Thanks for all your help!
And the servo saver should be parallel to the ground and At a right angle to the center line of th car. Please post a picture of your steering!!!
#5582
I tried to equalize servo horn travel R=L : Steering R=L....
Not quite yet but closer.
EPA = 61%L 82%R
Horn was 90 deg straight up and both tie rods were and are same length.
EPA was almost 100% to 65% right to left or vise versa.
Here are current pics. So... servo travel R/L should much right to left or closer is better right?
My servo horn tie rod never be straight parallel to center of the car. Also there is always angled in side view....
EPA = 61%L 82%R
#5583
You should shorten your rod that connects the servo horn to the servo saver. It just looks too long.
#5585
Look at page 9 of your instruction manual. Your turnbuckle should be in almost all the way in the eyelets. Get your calipers and measure the distance between the eyelets. If you dont have calipers, use the manual and put your turnbuckle against it on the manual. This will get you close enough.
#5586
Another thing...your servo horn is NOT going to be perpendicular to the chassis. Its going to lean a little towards the rear of the car.
The best way to get it centered is to attach the servo horn and turnbuckle to your servo saver. Center the wheels (point them straight). Hook up your radio. Turn it on and center the servo. Then attach your servo horn to the servo with the wheels pointing straight.
Im surprised your turnbuckle isnt rubbing up against the bottom of the top deck?
#5587
Thanks for all inputs. They all helped me a lot.
Here is an update(Pic)
Horn 90 deg
Tie rod parallel to center of car(Almost, not dead parallel I goes)
Tie rod is not parallel to chasis(Ground)
EPA for both RnL almost equal so servo travel RnL equalized too.
Horn 90 deg
#5588
Looking good, 91420l.
Today I went to the track and I "only" broke one outdrive of the spool (which I didnt have in spare ), but switched to the one of the TC6. Car was great, really great in the corners and is really 'crash' proof
#5589
Error
#5591
I think about few carbon parts to build better car
Just allow move outside lipo for L/R balance.
Just 1-2mm more then standard.
What do you think?
I do not want put lead, just 2mm outisde and problem is solved
Attachment 870202
Attachment 870203
m.
What do you think?
Attachment 870202
Attachment 870203
m.
#5592
which piston and bladder do you guys use/recommend?
#5593
No question in my mind... Reflex Racing
http://www.reflexracing.net/RSD-TC6A...15mm_p_11.html
http://www.reflexracing.net/RSD-TC6A...ers_p_528.html
#5594
45 front/35 rear with the Reflex parts seems to be my favorite combination.
