Team Associated TC6 Thread
#3286
Why, the S411 looks very nicely thought, a couple of guys here are going to get them in replacement to their T3s
#3287
regarding TC6 part
dear all, i having problem with the locknut #3904, it loose after i tighten it...anyone having this problem? any idea how to solve this problem?
#3288
if it is i too have had the same problem i stripped mine due to
bad allingment of thrust balls
#3289
Don't know how you can have bad alignment of thrust balls??
Anyway, it is know to strip easily if you over tighten the bolt in, so be gentle when you set your diff, Asso had a problem with a serie of nuts but this was a while back.
Solution: use some threadlock on bolt, make sure your diff is properly built too, I have seen diff not built properly on numerous occasions, use black grease to hold your thrustballs in place and compress with pliers the spring when it is new.
If it is gone, change for a new nut, they are cheap.
#3290
IMO the best solution is to buy #6575 Locking T-Nut, Diff thrust Bolt & Cover. #3904 is way too fragile, although if you follow olly986 advices you should not have problems.
#3291
trying to find some info on this tc6 factory team
do they come with a spool?
how strong are they? im not a bad driver just getting back into the hobby
What bad points there is to this car as the price is pretty cheap atm
#3292
IMO c-hubs are a little weak, but i just broke 1 since day one and been racing for almost six months on the car. Another weak point is the screw in steering blocks and rear hub. But spares are also cheap, and once you hit the track you will be surprised about the performance.
#3293
Yes, as Jorge says, not much more to worry about, wishbones on very bad bangs maybe, and spur gears are not top quality but this is like all other cars, and on the TC6 you do not need to change belts regularly, they last for ever...
#3295
Yes, that's the best solution. As I can't find the t-nut here.... I just use a tamiya diff nut (I think it is 2mm and the thread is all wrong). But as the nut is so small and soft just pre thread it with your diff screw before you put it into the plastic housing. Then just tighten it as normal. Been using this for over 2 month in the spool and no issue.
#3296
Ya, it is a good car. But you must change the kits plastic parts or the car is very very loose. (we run in very high grip indoor track). Personally the TC6 is a lot more stable for me especially for high speed layout. BTW: The 411 is sure a good car as the current fastest lap time is done by a serpent team driver with his 411. But he is a much better driver than me anyway. haha. Sorry enough for the 411 back to TC6.
#3297
I would wait to see what AE is going to come up first, they are plenty issues about poor quality on SpecR diffs for other models.
#3298
Hey guys,
just in case no one has mentioned it. There were questions as to what other kit springs will fit on the TC6. I found that the TM E4 springs are a direct fit and K Factory makes a really sweet set that are very precise with many compression rates.
Had them left over from my E4 cars and gave them a try. PREFECT fit!!
Just thought I'd share that...
#3299
Hey guys,
