Team Associated TC6 Thread >
Like Tree20Likes
Old 10-04-2011, 05:34 PM
  #4036
cwoods34's Avatar
For $22, no, not yet. But, it's..... TITANIUM! Technically it cuts weight, so not necessarily a downside to it.
cwoods34 is offline
Old 10-04-2011, 06:21 PM
  #4037
Odin544's Avatar
Trader Rating: 93 (100%+)
The titanium wont wear as fast as the standard shafts either.
Odin544 is offline
Old 10-05-2011, 02:57 AM
  #4038
Default TC6.1
"They have soft bladders out, and soon will have ECS shafts. I am testing a dual-arm steering setup and top-deck cutouts. The softer bladders are very nice --- I drilled a 1mm hole in the plastic cap and it makes zero rebound without a "foamy" feeling very easy to do."
I will some RSD soft bladers with 1-1-1.5 pistons soon.
Have you some feedback of dual arm steering ? Like TC4, but i have heard that TC3 steering was the reason why the TC3 was magic ?
Look at the Russian car steering....
"For the arms (especially the rear with toe-in) I just sanded near the arm mount where it might rub the bulkhead. This is essential if you run 2-3* toe-in with a narrow track width."
"I wouldn't mind titanium hinge pins myself "
I use lunsforg hinge pins, but i feel it is more smooth with standard ones, but in the order hand lunsford pins are lighters.
So the light of lunsford with the titanium smooth of the ballstud should be perferct.
Thank you for your answers
Fred
fredB is offline
Old 10-05-2011, 03:17 AM
  #4039
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
I know it has probably been answered before but just too lazy to search lol what parts are carry from the tc5 to the tc6? Suspension parts?
Marcos.J is offline
Old 10-05-2011, 04:34 AM
  #4040
Chaz955i's Avatar
Arms, c-hubs, rear hubs, steering knuckles. Shocks are a new design on the TC6.
Chaz955i is offline
Old 10-05-2011, 05:12 AM
  #4041
cwoods34's Avatar
Fred
The stock steering setup definitely feels more aggressive, which is fine for stock classes. I really notice a difference with the dual arm setup with low turn motors/mod motors, and on larger or more flowing tracks. It gives smooth, precise steering. I am using the XRAY setup, but tinkering with placement and servo location.
cwoods34 is offline
Old 10-05-2011, 06:44 AM
  #4042
Super Moderator
Marcos.J's Avatar
Marcos.J is offline
Old 10-05-2011, 07:05 AM
  #4043
Chaz955i's Avatar
You are welcome I believe when Associated first released the car they marketed the benefit to current TC5 drivers that most if not all of the suspension carried over to the TC6.
Chaz955i is offline
Old 10-05-2011, 09:09 AM
  #4044
Does anyone have a list of the lower arm mounts/bulkhead locations in order from lowest to highest roll center?
Obviously 0A would be the lowest... and 3B would be the highest. But what about in between? I see some people running a combo of 3A and 0B in the front... which is the lower roll center?
JamesL_71 is offline
Old 10-05-2011, 09:26 AM
  #4045
durtbag's Avatar
this helped me loads!
http://www.petitrc.com/reglages/asso...RollCenter.pdf
durtbag is offline
Old 10-05-2011, 10:04 AM
  #4046
Originally Posted by durtbag
Fantastic. That is exactly what I was looking for. Thanks
Old 10-05-2011, 02:39 PM
  #4047
There is plenty to read on PetitRC regarding setup and knowhow.
Mainly thanks to Arnaud who visits here also regularly.
olly986 is offline
Old 10-06-2011, 12:10 AM
  #4048
Hi is this kit all metric hardware?
zzztech is offline
Old 10-06-2011, 12:29 AM
  #4049
venom54's Avatar
Default METRIC
YES apart from the 2.56 bolt and nut for the diff !! You can replace with a 2mm bolt and Stainless M2 lock nut which will be better.
Cheers
Ren
venom54 is offline
Old 10-06-2011, 07:39 AM
  #4050
Trader Rating: 77 (100%+)
Default Diff ?
Can someone explain what the characteristic changes are in a gear diff with regards to different weight oils? What is the difference between "diff" oil vs "shock" oil. I see people using both. Lastly what weight is recommended for high bite indoor asphalt 17.5 NT
goin2drt is offline
