Team Associated TC6 Thread >
Like Tree20Likes
Old 08-04-2011, 01:45 PM
  #3436
Rick Hohwart's Avatar
Originally Posted by amygal
sorry , i mean jeff's 17.5 non boost setup
Got it. I am still waiting for the file. Once I have it I will post it with link.
Rick Hohwart is offline
Old 08-04-2011, 02:26 PM
  #3437
Hello Rick
i have seen many racers using the steering arms like the TC5 ie: ball stud on top rather than under like the TC6 manual, did you find a big difference and why changing this, and do you yourself use this.
olly986 is offline
Old 08-04-2011, 02:59 PM
  #3438
Originally Posted by olly986
Hello Rick
I only did it this way because everyone else was and this is how we ran the prototype. I have not tried it the way it is supposed to be in the manual.
Old 08-04-2011, 03:10 PM
  #3439
geeunit1014's Avatar
Trader Rating: 14 (100%+)
Hello Rick
It changes the bumpsteer, it makes the car smoother to drive
geeunit1014 is offline
Old 08-04-2011, 03:17 PM
  #3440
Hi Rick
It would be good to mention it on your setup sheets, obliviously someone using your setup on an inverted steering arm mount won't find it good I guess.I will have to try it myself.
Thank you
olly986 is offline
Old 08-05-2011, 05:11 AM
  #3441
Buckaroo's Avatar
The diffs are working great. Some small modifications to the tooling need to be made which will delay it slightly. But the plan is to have them in customers' hands by the IIC.
Rock on!
Buckaroo is offline
Old 08-05-2011, 08:15 AM
  #3442
New setup posted:
Jeff Cuffs ROAR Nationals 17.5
Old 08-05-2011, 08:21 AM
  #3443
Big Features's Avatar
Other then Shock oil and front ballstud hieght, very simular to what I run.
Nice job, Cuffy!
Big Features is offline
Old 08-05-2011, 08:46 AM
  #3444
Verndog's Avatar
Trader Rating: 16 (100%+)
Nice job, Cuffy!
Interesting. Your running without anti-roll bars as well?
Verndog is offline
Old 08-05-2011, 08:59 AM
  #3445
jag88's Avatar
Just curious, does anybody have any experience with running different diff heights ?
Thanks.
jag88 is offline
Old 08-05-2011, 09:39 AM
  #3446
Warren Weaver's Avatar
Trader Rating: 49 (100%+)
Thanks.
i run my gear diffs low in front high in rear.
Warren Weaver is offline
Old 08-05-2011, 10:24 AM
  #3447
jag88's Avatar
What do you notice the car does with that set up ?
Does it fix a problem you had before ?
Thanks.
jag88 is offline
Old 08-05-2011, 12:03 PM
  #3448
Suspended
Trader Rating: 86 (100%+)
what shock length and rebound do you guys use?
is 63.7mm too long?
littlealex is offline
Old 08-05-2011, 12:30 PM
  #3449
Thanks.
seems to let the rear roll more just like the feel with the diffs set in that position very comfortable to drive fast
Old 08-05-2011, 02:14 PM
  #3450
hanzo3's Avatar
Trader Rating: 55 (100%+)
I keep stripping my steer blocks. How do I correct this? It seems like the front right one is always stripping. This causes me to lose a C blade and then will cause a worn outdrive. I am using the regular hard blocks.
hanzo3 is offline
