Team Associated TC6 Thread >
Like Tree20Likes
Old 07-18-2011, 10:29 PM
  #3271
Originally Posted by olly986
Well, I have just fitted the Sakura diff gear in my TC6, no dremel here only a couple of parts changed.
You need a set of outdrive from a RRR V1 kyosho ref No: VZ219 (can be found cheap now)
I changed the internal gears for NT1 metal ones, the originals were plastic, but I guess they will do too.
The bearings are the same size, there is plenty shims to adjust your diff.
And you need a 40t diff which comes extra. (37 and 38 gears are standard in diff, 39 and 40 are separate spares)
It could be interesting to try a 39t on front...
On the minus point, you cannot use blades anymore, except if you remove some of the outdrive, which I did not want to.
So instead, I fitted some heatshrink on the ball and pin ends, it fits nicely with smooth action.
I am at the track tomorow to test all this if weather permits.
Is the sakura diff a bit too wide of the TC6? I think I measure it before but can't remember..... BTW: With my old sakura I change the drive shaft and out drive to Edam spirit (a 1/10 nitro touring from taiwan). It was a perfect fit for the sakura. Think it should work with TC6 too.
gpm-parts.com is offline
Old 07-19-2011, 12:19 AM
  #3272
Suspended
Trader Rating: 86 (100%+)
just got a tc6, wondering what body is comment for this car and what do you guys ususally upgrade for this car
littlealex is offline
Old 07-19-2011, 01:25 AM
  #3273
Originally Posted by Buckaroo
Kimbrough medium servo saver. Problem solved. The very same mod has been very well and completely researched/tested in the Photon.
Of course a servo saver is the solution but this is not what PIMP seems to be saying, I was already using Kimbrough savers in the 80s and still have a couple around.
olly986 is offline
Old 07-19-2011, 01:30 AM
  #3274
No the Sakura fits fine, it needs a few shims behind the bearings but all is good, shame the outdrives are not direct fit, they are very small and the bone doesn't get near it.
Was hoping to race today but weather is bad, so have to postpone.
olly986 is offline
Old 07-19-2011, 03:21 AM
  #3275
For bodies it depends on the track but i use mostly Mazda6Speed and LTC from Protoform.
Upgrades:
- Gear Diff - for sure
- 3942 - 1 pair of silver associated springs
- 3943 - 2 pairs of blue associated springs
- 31262 - Silver anti-roll bar
- 1402 - 2 pairs short turnbuckles
All the rest comes with the kit. By the feedback of drivers around here maybe some Reflex Racing parts should be a nice upgrade also, but personally i've never tested them.
jorgesimes is offline
Old 07-19-2011, 05:25 AM
  #3276
Buckaroo's Avatar
There's still the servo saver, as built into the steering bellcrank, too. No idea what a "mount saver" is, or why you would even need to save the mount.
Buckaroo is offline
Old 07-19-2011, 07:08 AM
  #3277
turbodog's Avatar
Upgrades:
6* castor blocks
and the 1/12th .5, 1, 2mm shim kits for the suspension mounts
turbodog is offline
Old 07-19-2011, 07:12 AM
  #3278
Originally Posted by turbodog
6* castor blocks
well-minded.
Old 07-19-2011, 12:09 PM
  #3279
Hi Olly,
I just got a TC6 and have some spare Sakura geardiffs i want to try, but they appear to have a slightly different pitch on the pulleys.
Did you have any trouble with the Associated belt on the Sakura pulley?
Magneto is offline
Old 07-19-2011, 12:20 PM
  #3280
Trader Rating: 77 (100%+)
well-minded.
The PPB billet suspension mounts are a nice addition. You don't "need" them but you may "want" them. I am a believer.
goin2drt is offline
Old 07-19-2011, 01:58 PM
  #3281
Suspended
thanks for the suggestions guys!!
Old 07-19-2011, 02:30 PM
  #3282
Originally Posted by Magneto
Hi Olly,
I fitted a 40t, like that it seems fine, but unfortunately, no try today, bad weather, so I will post as soon as I have given a few laps.
olly986 is offline
Old 07-19-2011, 07:00 PM
  #3283
Q. does the TC6 have wider shock bodies then the TC4.
bosco72 is offline
Old 07-19-2011, 07:22 PM
  #3284
Maybell's Avatar
The bodies inner diameter are the same. They use the same size pistons and springs.
Maybell is offline
Old 07-19-2011, 09:53 PM
  #3285
oh cool. thank you for your reply! After switching to s411 for one month I was thinking going back to TC6. Stupid I sold my TC6 already..... ya, the of the drive shaft's "head" is much bigger in the TC6. Just a bit smaller than the T3.
