Team Associated TC6 Thread >
Like Tree20Likes
Old 11-23-2011, 11:12 PM
  #4771
hacker's Avatar
Trader Rating: 141 (100%+)
Originally Posted by Kody
Yea its a solid style spool with plastic cups. If I'm not mistaken its lighter then the slipper spool.
K
thanks, that spool is welcomed, along with the gear diff. I'm currently locked up tight on the spool, but feel its not 100% locked up and may be losing those precious few inches coming out of turn hard on the throttle. I have heard of guys using sandpaper as the slipper pad to prevent slippage, but thats just too much work for me
This new car will get me back in the game
hacker is offline
Old 11-24-2011, 02:33 AM
  #4772
Thats not that hard work
Olly Jefferies photo.
jorgesimes is offline
Old 11-24-2011, 05:21 AM
  #4773
Originally Posted by burgboyz
Thanks for all the up to date info Rick!
did Juho using double join instead of AE CVA in front during ATS?
mos-leung is offline
Old 11-24-2011, 06:53 AM
  #4774
rangerjkb's Avatar
Trader Rating: 45 (100%+)
Still being new to Onroad, after a minor front camber change at practice session yesterday, my TC6 is on pace with local fast guys. They are currently running foam tires on asfault, whereas I am using rubber tires. They still have an edge in/out of turns, but I am very pleased with the TC6.
*Would it help or hinder (handling or tire wear) adding ?mm spacer to the front upper C-Hub camber link ball location? Appreciate any assistance provided.
rangerjkb is offline
Old 11-24-2011, 06:58 AM
  #4775
How much mm do you have and what's your camber link position? For me the best feeling i got was with 7 camber position and 2mm with silver ballstud in the c-hub.
Old 11-24-2011, 07:35 AM
  #4776
Originally Posted by Rick Hohwart
This is just something I started with to play around with and it worked well. I previously used my typical TC6 setup "converted" to the new car and it worked equally well. With a new car we are trying some new things that may or may not be better in the long run but are more in line with what other cars use. The object is to make the car easier to drive fast for the majority of the drivers using it.
Juho's ATS setup shows 3A all around.
Expanding on that, I noticed Juho was also using the short camber links, front and rear. And the new "Baseline setup" for the TC6.1 is using the short links... just as you and Keven's WCRC and Timezone setups are.
Is this just an evolution in setup? ie: You guys are now finding that the short front links are quicker in some cases.
Or is the fact that the short front links are now working directly related to the new TC6.1 suspension plastics?
JamesL_71 is offline
Old 11-24-2011, 08:32 AM
  #4777
jag88's Avatar
The instruction manual says that as a "Racers Tip" you should ca the inserts in place for the c hub and rear upright.
I'm wondering why have inserts ?
jag88 is offline
Old 11-24-2011, 08:46 AM
  #4778
I was thinking exactly the same. I don't see the benefits of inserts when I have to glue them.
On other cars you just insert them and they stay there.
dennisV is offline
Old 11-24-2011, 08:54 AM
  #4779
Brian McGreevy's Avatar
I think the thought behind that was just a dab of CA to keep the insert held while doing maintenance, but little enough that you can break the bond pretty easily if you are trying to.
Brian McGreevy is offline
Old 11-24-2011, 08:55 AM
  #4780
I suspect you dont have to glue them... but CAing them will probably reduce suspension slop slightly. *dunno*
Old 11-24-2011, 10:12 AM
  #4781
rangerjkb's Avatar
I have it in the #7 hole, currently running 1.5* front camber, and no spacers under front ball stud on top of C-Hub. I hope not to loose intital and midcorner steering, but see many setups using 2mm ball stud spacer.
Old 11-24-2011, 10:16 AM
  #4782
Rick Hohwart's Avatar
what's the story with the new spool? Is it solid, unlike the current slipper pad design?
It is solid. But unlike the original TC5 solid spool this one captures the blade.
I actually prefer the long link in front. Using the short links is just a way to try and find more speed. The standard Tc6 setups converted for use on the 6.1 will work great.
You do not necessarily have to glue them. One of the main reasons for inserts is so that racers and dealers don't have to stock 3-4 different parts. Instead you only need one part in your box that can be configured how you want it to be.
Rick Hohwart is offline
Old 11-24-2011, 11:29 AM
  #4783
Rick,
What is the goal of AE to have more rigid arms ?
It is nice to see the TC6 moving into TC6.1.....
A new car for chrismas !!!!
Regards.
fredB is offline
Old 11-24-2011, 12:32 PM
  #4784
hacker's Avatar
I have too much rear grip, especially off power. I've put on a harder rear roll bar, 14.5 rear spring, less front droop, more rear droop, moved rear shock out 1 hole, slightly stiffer rear shock oil, reduce rear toe in, forward 1 hole ackermann. Goop the whole front tyre. Funny enough none of the changes made much difference, if any.
I do have 6 degree caster block on, only cos they were the only ones I have as spares at the time. Should I go back to 4's?
What would be my next step, regarding roll center changes or any other changes? I don't have the correct length turnbuckles for front link changes though....
lengthen rear camber link?
I'm bit dumb with car setup
hacker is offline
Old 11-24-2011, 01:24 PM
  #4785
wtcc's Avatar
I think it would be better to just reduce the caster on the rear axle. Maybe a total of .5 - 1.0 mm less shims under the rear armmounts would make your car turn better.
wtcc is offline
