Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree6563Likes
USGT
Last edit by:
Print Wikipost
Old 04-29-2016 | 05:58 PM
  #4801
ThrottleKing's Avatar
Protoform has a new Corvette for 1/8. Only a matter of time and we will have a 1/10 version.
ThrottleKing is offline
Old 04-29-2016 | 07:38 PM
  #4802
robk's Avatar
Not sure about that, I think Vaterra has the 1/10 rights for a couple years from what I hear.
robk is offline
Old 04-29-2016 | 08:08 PM
  #4803
Thanks Rob for taking a poop on my hopes.LOL
Old 04-30-2016 | 04:10 AM
  #4804
I'm too busy twirling my mustache and pooping on your hopes.
fixed
nwagner is offline
Old 04-30-2016 | 05:51 AM
  #4805
JCarr's Avatar
The exclusive rights vaterra had on the Vette ended 12/31, that's how PF was able to do the 1/8 body now. There should be a 1/10 coming soon, I hope.
JCarr is offline
Old 04-30-2016 | 06:28 AM
  #4806
BadSign's Avatar
Unpooped!
BadSign is offline
Old 04-30-2016 | 07:10 AM
  #4807
Is anyone familiar enough with specs of the BSR BT-4 21.5 RTR to tell me if it is good to go for racing USGT out of the box. I'm wondering about the front dif in the car vs USGT rules but am pretty new at this still so not sure.
Jsapata is offline
Old 04-30-2016 | 07:29 AM
  #4808
theproffesor's Avatar
You can run a diff in the front, there are no rules against it. I have one in the front of my Tamiya Evo6 that I run. You want to put a very heavy fluid in it though. 500k - 2.5million weight.
theproffesor is offline
Old 04-30-2016 | 10:59 AM
  #4809
1spunspur's Avatar
Originally Posted by SpeedySST
As a nitpicky purist, any sort of PROTOTYPE body should not be allowed since they are NOT GT cars. As a toy car racer, I say let em race. You're right, if it gave some sort of magical advantage, everyone would run them and there would be no Cadillacs or, in the case of Eric Epp, the Lexus body he ran at MHIC which looked awesome. Besides, everyone knows that its the anodized aluminum parts (especially purple) that make the car go faster.
Yes. Anodized + Aluminum = more faster.
1spunspur is offline
Old 04-30-2016 | 12:41 PM
  #4810
BadSign's Avatar
And pretty wiring. That'll get .2 seconds every time.
BadSign is offline
Old 04-30-2016 | 03:25 PM
  #4811
DARKSIDE's Avatar
shorter wires less weight...faster car
DARKSIDE is offline
Old 04-30-2016 | 04:38 PM
  #4812
GasGod's Avatar
It comes stock with a spool;change tires/body and go
GasGod is offline
Old 04-30-2016 | 04:43 PM
  #4813
Trez83's Avatar
I also run a diff in the front of my Serpent Eryx. I use 2.5 million weight fluid. Car has crazy good turn in and the longer you run, the better the front grips. I recommend it highly. Plus, it's a lot less wear on the drive gear than a spool.
Trez83 is offline
Old 04-30-2016 | 06:52 PM
  #4814
mikel33's Avatar
I always thought the power got from the battery to the esc and then the motor faster if the wires are shorter.
mikel33 is offline
Old 04-30-2016 | 07:40 PM
  #4815
JEFFs SC10's Avatar
Originally Posted by howardcano
They are both excellent classes for someone with experience with RC, which you seem to be. My suggestion is race BOTH classes!
you read my mind.
JEFFs SC10 is offline
