Like Tree2Likes
Losi XXX-S
Old 04-18-2004, 07:34 PM
  #10006
Cardboard's Avatar
check for moisture in your esc. also, check the wire insulation to make sure they aren't shorting.
Cardboard is offline
Old 04-18-2004, 07:47 PM
  #10007
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Get a good ESC and then you'll never have to worry about a 15t motor.
Randy Caster is offline
Old 04-18-2004, 07:48 PM
  #10008
JayBee's Avatar
Trader Rating: 31 (100%+)
The reason I was shocked was because the only thing I changed was the motor, everything else came stock with the RTR Losi. The ESC is GM Racings' V3R (supposedly able to handle no less than a 15t motor). The leads did melt themselves together though. And the ESC was EXTREMELY HOT!! So I came to the conclusion that the esc was not able to handle the 15TDouble Mod motor.
JayBee is offline
Old 04-18-2004, 08:22 PM
  #10009
subman's Avatar
my guess is that your gear mesh was to tight. A peice of paper should go between the spur and pinion with out ripping.
subman is offline
Old 04-18-2004, 08:35 PM
  #10010
Trader Rating: 16 (100%+)
Now that I see it was a 15 turn double, I have to think that a double pulls more power than a 15 turn single.
Still Bill is offline
Old 04-18-2004, 08:57 PM
  #10011
JohnMatrix's Avatar
No Sh*T?
JohnMatrix is offline
Old 04-18-2004, 09:23 PM
  #10012
JayBee's Avatar
XXX-S Bill--
That's is my conclusion too, so I'm getting GMs' V6R.
That should do the trick. This also gives me a chance to concentrate on the Yoke SD that I just built.
Thanks guys
JayBee is offline
Old 04-19-2004, 06:15 AM
  #10013
clinttredway's Avatar
Default First Race
Yesterday was my first race with my Losi...
Didn't do too bad, 4th in the B. One thing I noticed about this car was the ability to get off the line FAST! I would hole shot everytime just to get punted in the first turn..
Oh well... ver smooth car.. I have a black belt kit on the way so we will see how that changes things. At my track 99% run XRays and there are only 4 Losi's (me included) and they are a little quicker...
clinttredway is offline
Old 04-19-2004, 06:54 AM
  #10014
RandyB's Avatar
Does anyone know where to get new pullies and belt?
who had them in stock???
RandyB is offline
Old 04-19-2004, 07:03 AM
  #10015
If you are talking about the new kits. stormer has them in stock. I bought 2 of them last thursday.
Clint
Old 04-19-2004, 09:16 AM
  #10016
I'll probably check with my local shop today and see if they have any new belt kits in stock. Got to check on the one way and some other stuff too. I found out my car should be here on Thursday. Just in time for me to go back to work. I'll cross my fingers and hope it's Wednesday.
wcoyote is offline
Old 04-19-2004, 09:46 AM
  #10017
NVisible's Avatar
Default Re: First Race
i found the same thing. racing vers a few tamiyas and a TC3 in my first race, in a B main as well. I would out punch them easily, even with my no name 1800s.
I just put a black belt system in mine, havent raced it yet tho
NVisible is offline
Old 04-19-2004, 12:26 PM
  #10018
Cardboard's Avatar
i'm almost sure the v3r has an 18t limit.
Old 04-19-2004, 01:36 PM
  #10019
Default New Belt Kits
How much of a difference is there between a cut yellow belt and the new black belt?
thanks for your input!
Old 04-19-2004, 01:44 PM
  #10020
RandyB's Avatar
I dont know by first hand knowledge but I have been told the car is alot more free and adds run time with alittle more rip. the pully system is larger allowing a larger belt and a less binding drive train
RandyB is offline
