Losi XXX-S
The carpet just doesn't have enough bite yet to be running stiff setups like that. Cyan/Magenta are a softer tire and I thought they really gave me the grip I wanted to push it harder. Carried a lot of corner speed.
Originally posted by DavidAlford
Thats your problem. Ditch that motor. Its got no punch at all. Get you a good monster stock and start about 31/128. Run is a few mins and check the heat. If its too hot the go down a tooth. That quad mag stock is just....whats a nice word....slow.
Ok. I got this car from one of the other racers and this was his setup. I like it, but I am willing to try other options.
I will change my car to this setup and do some testing...
Thanks David.. I really appreciate the advice.
No Problem, its what I'm here for.
Originally posted by mwcet8k
So you think it's a good idea to run a lower ratio with the monster stock? I've always heard that you typically want to run a slightly higher ratio with that motor compared to other stocks.
By the way, are you running the new kevlar spur? If so, what do you think about it? I'm running 48P gears right now, but I really like my cars to run as quietly as possible, so I'm thinking about switching to 64P. What type of pinions do you use?
I am running the non-kevlar 128 64 pitch with Robinson pinions and its quiet as can be...
Which Robinson pinions? Purple or black?
Black
Kevlar is going to be tough to strip, but louder. It's also heavier then the stock blue spur.
When it comes to the spur gears.....I can tell you about half of the team guys were using the blue one and the other half were using the kevlar. Those using the kevlar had drilled it out to lighten it up. They didn't seem really any louder to me, though I did spot one driver putting some of that pink aero lube on his spur/pinion. His car was ultra quiet....
There were a few drivers using a plastic gear adapter and using aftermarket spurs.....Kinwald had this setup.
Later EddieO
Later EddieO
i find my kevlar to be louder than the blue gear, i run robinson pinions too.
R/C Tech Elite Member
I've had good luck with the Binary 2 motors once I learned how to tune and gear them. Try Trinity purple springs, Reedy 767 brushes, and gear it 30/128, should be a good setup, mine has only been faster than the monsters..
It's 3 teeth
But it's fast... The worst that can happen is you'll cook some brushes.
