Like Tree2Likes
Losi XXX-S
Old 01-13-2004, 05:36 AM
  #8431
Mark David,
Buy the BRP front bumper and you'll be very happy.
http://horizon.hobbyshopnow.com/serv...=ALL&tag=qsrch
Mark
munrath is offline
Old 01-13-2004, 06:22 AM
  #8432
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
Hey Mark when did you get a Losi? No more Yoke!!!! I got a TC3 as my Yoke kept gitching with 2 different radios and then I sold it to a buddy and he kept glitching with it as well so he just sold it. Too bad as it worked pretty good.
wyd is offline
Old 01-13-2004, 08:47 AM
  #8433
Will that same bumper help with the front suspension/droop screw flex problem?
wcoyote is offline
Old 01-13-2004, 10:03 AM
  #8434
Wcoyote,
No. I wish though.
Mark
munrath is offline
Old 01-13-2004, 11:07 AM
  #8435
Registered User
Any one going through one-ways on carpet with rubber tires? I went through three last weekend! Either the bearing pins came out or they seized completely.
B1015er is offline
Old 01-13-2004, 11:11 AM
  #8436
The one ways can be quite weak sometimes, I carry some extras when I go to the track. I saw quite a few go out this past weekend.
James Nguyen is offline
Old 01-13-2004, 11:25 AM
  #8437
Barry White's Avatar
You should get the Tech-Racing one way. These are bullet proof. They have one piece metal outdrives and 6mm one way bearings.
Barry White is offline
Old 01-13-2004, 12:28 PM
  #8438
Kevin K.. Thanks for the words.. the car was good all weekend. Showed all those shaft cars what was up. Anyways.. heres the setup I ended up with. If I forgot anything let me know.
Front
Oil- Losi 40
Piston- 57
Spring- Trinity Purple congo
Caster- 6 degree
Link location on tower- above and between 2 & 3
Shock location on tower- 2
Roll center- Low
Droop- 2
Toe out- 0
Camber- 1
Ackerman- forward and flipped
Pivot support- 0f
arm spacing- front
Sway bar- .070
Tires- 30mm cyan cut to 28mm
Rear
oil- Losi 40
Piston- 56
Spring- Trinity Blue congo
Link location on tower- 1
Roll center- Low
arm spacing- back
Toe in- 2 degrees
Droop- 2
Pivot support- 0R
Camber- 1
Hubs- off set
hub link locaton- A
Tires- 28mm Magenta
Sway Bar- .050
Body-Losi Alfa
Batteries forward
Ride hieght, 4.5mm front and rear.
AE hexes front and rear
Gearing- Stock w/ a Monster- 32/128
19T w/ a C2- 38/128
Bobby Flack is offline
Old 01-13-2004, 12:37 PM
  #8439
The Evicerator
Good job at the race Bobby...and welcome to Losi
Steve Weiss is offline
Old 01-13-2004, 12:52 PM
  #8440
Thanks dude!
Old 01-13-2004, 01:51 PM
  #8441
Bobby Flack, good run. What size were your foams after your main?
ZER01 is offline
Old 01-13-2004, 01:56 PM
  #8442
J.Filipow's Avatar
Trader Rating: 15 (100%+)
Flack- Congrats...thanks for posting set up info as well.
J.Filipow is offline
Old 01-13-2004, 01:57 PM
  #8443
pro3racer's Avatar
Are the AE hexs wider, and increase the width of your car? I'm thinking they prevent you from having to grind anything down when running 28mm.
pro3racer is offline
Old 01-13-2004, 02:32 PM
  #8444
I lost a couple this weekend in Stockton on carpet, also. Where can you find those? Thanks, Ryan
Ryan C. is offline
Old 01-13-2004, 02:51 PM
  #8445
RCTech Member #2
TSR6's Avatar
With the stock losi hexes, the foam tires will rub the bottom shock eyelet at full lock. With the AE hexes, it spaces the wheels out a little more, adding clearance.
TSR6 is offline
