Losi XXX-S
#7681
Originally posted by JitsuGuy
Has anyone bought another set of hubs to rule out whether they're the problem or not?
Thanks,
J
Thanks,
J
#7682
real quick.
Hey does anyone know where i can get the complete screw kit in blue for my G+?
#7683
I believe the problem lies in the roll centre blocks or mounts. If they are not in line properly when fastened it will change the angle of toe in. The hub carriers and the rear arm tolerence doesnt change.
Have a look at that and see if that fixes it.
Cheers Bill
Cheers Bill
#7684
Re: real quick.
Rob
#7693
i just got a xxx-s g+ and i need some setup advice for carpet
i havent been racing onroad any for a while so i dont remember much
what tires are recommended we run foams and i was told plaid fronts and magenta rears trc tires but i would rather run something other than trc tires if i can speedmind tires are perferable because they are cheaper and easier to get
and what can i do to stop the shocks from leaking it seems the front shocks are nearly empty after a little more than a weeks time or is it because i need to rebuild them weekly
#7694
When you install the new O-rings, if you have it, put some AE Green Slime on them. If you don't, a drop of shock oil will work too, just so that the o-rings aren't dry when you push the shock shaft back through them.
Also make sure the threads on your cartridge are in good shape, and that you tighten it well when you rebuild the shocks. They need to be more than just finger-tight.
#7695
the shocks are brand new and ive had to rebulid them once already
i put a drop of oil on the shafts when i was building them like it said to do in the instructions
should i tighten the cartridges with a wrench or something
i will replace the cartridges if thats what i need to do but they are really new so i dont think they are the problem
