Losi XXX-S
#451
Suspended
TC3 Anyone???
Originally posted by Wolverine
Yes I know that the losi's drive ratio is different then the tc3
but I geared them as close as possable using a calculater.....
and the losi was slower, I even told that to the people who I talked to at losi, they asked how I geared it and what was was my finale gear ratio, and said that the small differents should not have show up in the speed loss between the too.....
They think was that something was bending........
but I don't know, I have to wait and see what losi sends me.
#453
any good setups for untreated parking lot tracks?
#454
you can't run the same gearing from the TC3 on the Losi. You may have to gear up 1-2 teeth to get the same speed. I don't know why that is but from the testing that we have been doing that's what everyone has ended up doing. Listen to your motor in the Losi. Is it winding out at the half way point on the straight? what motor and spur gear are you currently running?
#455
Originally posted by Jeff Werner
Wolverine, I have a nice Tc3 that I am trying to sell/trade. May be interested in a trade if you want to move the xxx-s.
Let me know.
Jeff Werner
Let me know.
Jeff Werner
but I want to wait to see what losi does.....
#456
well were to start........... it is slow!!!! even with it geared the same.......... and the same motor
I have broken 3 arm's......... 2 front, one rear
not counting the damage from the crash... ( girl watching )
an arm on a XXX-S, but then again he spent the better part of every lap bouncing off the boards... finally caught one just right...
the belt broke!!!!........ with a stock motor
I have had to rebuild 3 of the four shocks now........
it is just JUNK!!!!!!!
even the kit it self, was bad.........
missing screws, broken o-rings, a lot of flashing to clean of the parts, a bad bearing...............
#458
seamus0g - I have heard of one.... and only one belt breaking othat that Wolverine's... but he said he did something to it before it broke... and i don't remember what.
All i can say is the car is one tough cookie.. I've hit my fair share of boards with the "Drive by Braile" method of driving... The worse damage i have done to it is a pop'ed ball cup.
#459
seamus0g:
As I was told by losi that some times thing happen, sometimes there are flaws in parts, I may have gotten a bad kit
It happens in the real world all the time
you can buy a new car it turns out to be a lemon......
things happen.........
All I know is that Losi was more then wiling to help me out......
I have gotten extra parts in losi kits before, or sometimes you get too lefts of something or too rights.......
it happens........ I may have gotten a bad kit......
but losi is going to fix the problem
and that is all that counts............
#460
R/C Tech Founder
Originally posted by seamus0g
And once again, nobody I know had any missing parts or had any of these problems. The whole story is suspect... I don't buy it.
#461
MR Losi -
I see that you have raced Trackside before, I am going to be in the Milwaukee area over thanksgiving to visit with family and will probably bring the losi sled with me...need something to do when the family drives me nuts!! Anyway, I am looking to see what you guys are running for setups.
I currently run the car on sealed asphalt, tight track (SRS - Scottsdale, AZ), and haven't run on carpet for a long, long time (since trackside was on Bradley in the shopping center).
Thanks in advance to anyone with a little bit o info!
Wilde
Wilde
#462
As for the missing parts - I have been missing little things here and there in some Losi kits too, but this one was complete. Losi weighs each box after packaging, so a couple of little parts here and there are bound to be missed - call it human error. Losi has always been nice enough to fill the parts...then you will have extras.
#463
hehe, I just noticed that I am a rookie again!!! woohoo.
Anyway, Wolverine, as a couple of other people here have stated, there are some issues in your statement. First off - the belt breaking. I haven't seen one yet that broke....or even shows signs of wear. I run a 11D in mine. I checked out the belt last night just because I was curious. It looks like the day I bought it.
As for the arms..sorry to say it, but unless this car takes a TOUGH hit, it doesn't break. Quit hitting things...don't blame Losi for this one.
Flashing on the parts?? unless you purchase aluminum parts, there will be flashing, AE, Yoke, HPI, all of them. Just trim it off with a knife and all is good.
As for the binding, I would agree. Blown bearing, broken belt, slow car, ummm yup. Something wasn't either molded right or put together wrong. I put them in that order to give you the benefit of the doubt here.
Wilde
Wilde
#464
tufferwilde - Check out Paul Lemeiux's carpet setup on the Losi website for a baseline. Carpet is still brand new and still a little loose. By Turkey weekend the traction should be up and setup can go a little stiffer overall. Sorex 24's with medium liners unless you have Pit 25's in you box.
