Like Tree2Likes
Losi XXX-S
Old 10-29-2002, 02:03 PM
  #4231
OBY
OBY's Avatar
i run in really bad rain...the losi goes really well in it, handles like a dream, i go better in the rain than the dry!! only problem i've had is the four main diff bearings going, but thats nothing...
OBY is offline
Old 10-29-2002, 02:39 PM
  #4232
Regional Moderator
BHenderson's Avatar
Senna,
I think it would be easier for the guys here to help you if you could tell them the entire setup on your car at one time.
The following link is a Blank Acrobat reader editable Losi XXX-S setup sheet. Fill out the sheet and print it out, or if you have the full version of acrobat reader save it, and that way the guys here in the know can help you out.
Editable Losi XXX-S Setup sheet
Hope this helps you out
BHenderson is offline
Old 10-29-2002, 04:00 PM
  #4233
Originally posted by TSR6
I did the same. Great idea untill you stuff a pole once or twice. Batteries slide forward.
Put a piece of foam in that extra space if your having that problem
ZER01 is offline
Old 10-29-2002, 06:58 PM
  #4234
shrekair's Avatar
Trader Rating: 9 (91%+)
my standard carpet rubber setup
File Type: txt
xxx-s rubber txt.txt (4 Bytes, 185 views)
shrekair is offline
Old 10-31-2002, 12:50 AM
  #4235
Shrekair,
The file you posted above doesn't seem to contain any info,
unless of course its me!!!
By the way does anyone have a setup for the Losi running indoors on a sports hall floor which will either be vynil tile or wood but either way will be really slippery. I will of course be running a stock motor
Bosscat is offline
Old 10-31-2002, 06:35 AM
  #4236
lem2's Avatar
Default December Issue
Hello guys!!!!
The december issue of R/C Car Action had an article about the TC3 and XXX-s being "head to head"
so what is really the difference between the two? aside from their drive train?
and the article, did not say which was better?
any comments?
will i make the xxx-s my christmas gift? hehehehehhe
lem2 is offline
Old 10-31-2002, 07:01 AM
  #4237
RCTech Member #2
TSR6's Avatar
Foam probably wieghs more than what i shaved off.
TSR6 is offline
Old 10-31-2002, 08:03 AM
  #4238
Looks like someone needs a new battery strap
ZER01 is offline
Old 10-31-2002, 10:37 AM
  #4239
RCTech Member #2
TSR6's Avatar
http://www.shearracing.com/tsr6/xxxs/losi12.jpg
You can see it there...
I have a spare graphite one from the conversion.
-T
TSR6 is offline
Old 10-31-2002, 10:54 AM
  #4240
Looks good T, I like how you took more off than mine. I've never had the problem of my batteries sliding but then again I've always run them in the forward postion. Nice pic.
ZER01 is offline
Old 10-31-2002, 02:14 PM
  #4241
RCTech Member #2
TSR6's Avatar
The pic is old, last June i think?, I should update my stuff.
TSR6 is offline
Old 10-31-2002, 09:13 PM
  #4242
srfreeman's Avatar
lem2,
Thats a hard question to answer! I've owned both and I'm currently racing the xxxs. I like the losi cause I think its easier to work on and if you ever run in a parking lot the enclosed drivetrain is nice! Also, it seemed that I broke a lot more a-arms and bent inner hinge pins, but I've heard since I had it they've updated the parts a little. The losi just seems more durable and less prone to tweeking in a crash. As far as performance, I don't think one has a distinct advantage over the other, thats probably why they didn't say anything in the mag. Take a look at both, and just choose whichever one you like better!
Thats just my opinion!
srfreeman is offline
Old 10-31-2002, 10:00 PM
  #4243
shrekair's Avatar
this one time, at band camp, this girl came with a xxx-s and another girl came with a tc3. annd they got really pissed off, and then a bear came. then all 3 got into a fight. then the bear ate both cars and the girls, the they had to kill it so they shot it and it died. in the end, it doesnt matter, because when they cutt the bear open the tc3 had a losi internal ratio, and a belt!
shrekair is offline
Old 10-31-2002, 10:02 PM
  #4244
ijnek's Avatar
red or blue???...which is better???...
i bought the xxxs over the tc3 bcos of the torque steer which is present in shaft cars especially on low-traction surface n tat's 1 of the main place tat i run my car.
some may argue with mi abt the torque steer on shaft cars,but u have 2 b a gd tweaker to solve the problem which i admit i'm not.
red is fury on track!!!...
ijnek is offline
Old 10-31-2002, 10:05 PM
  #4245
ijnek's Avatar
huh???...i dun get it
ijnek is offline
