Losi XXX-S
#4066
i had no problem throwing my 3xs around corners as long as i keep my cool...
any1 experience with overdrive yet?...
my feeling is tat overdrive will make the car feel more like forward wheels driven and underdrive will make it behave like a rear wheels driven car,...any1 done any testing on this yet?...
#4067
Referring to your previous replies ... it seems that the .28 shock shafts are used only on the front !
What is the best shock shaft for rear ? (0.36) ?
#4068
senna, stay with .36 for the rear, .28 is too short
ijnek, I've run both over and underdriven set-ups. Overdrive pulls the front wheels round the corner under power and gives more steering on power but less off power. I also found that it kept the rear in line and stopped it from breaking loose, it just followed the front round the corner
I sacrificed some old Pro-10 rear tires to stop the battery pack from falling out of my car, it happened twice in one race!
#4070
TSR6- For oneway maintenance, I just run the crap out of it and then buy a new one at the begining of the next season. It may be sad to say but when I have tried to clean and relube oneways they have allways felt poor after, so I just spend the money.
Chad
Chad
#4071
Spring Rates
Hi Guys
Thank you for the replies. Yes I noticed most people use different springs than Losi, especially Trinity.
Thank you again for your help
#4072
For my one way I used to spray and the berings with motor spray then run Assoc. black greese in the one way it self. It felts stiff for a while then frees up after one run.
#4073
I lube my one-ways with HPI ceramic grease. It's a silver color and comes in a small blue jar thingy that's about the size of a bottle cap. I just scrape out a small amount with an x-acto blade and put it on a couple of the rollers in the bearing and it works like a champ.
#4075
#4076
seems let overdrive is interesting n really makes my theory make sense tat overdrive will b inducing forward wheels driven effect!!!...
#4078
i remember tat the internal drive ratio is like 1.883 rite?...
have 2 check the menu 4 the exact value...
as 4 ur question.i guess tat depends on how u gear ur car rite?...
1'm running 88spur on 25 pinion for stock...
