Like Tree2Likes
Losi XXX-S
Old 03-14-2002, 10:23 PM
  #2266
CreepingDeath's Avatar
A small track might be too difficult to run a 1-way. A large open "flowing" "fast" track might be too easy to run a 1-way.
CreepingDeath is offline
Old 03-14-2002, 10:27 PM
  #2267
Ill Factor's Avatar
Default GM batteries
Does anyone know if these are anygood?
Ill Factor is offline
Old 03-14-2002, 11:08 PM
  #2268
Food for thought on the front ball diff versus front one way.....the 2nd place finisher in Mod.....ran a ball diff front and rear....in the 2001 ROAR Nats.....and from all people.....Matt Francis!
The one way provides a little more topend, allows you to corner better in sweeper corners (more speed), but does require a different driving style.
A one way allows the inner tire to freewheel whilethe outer rim still has power applied to it.......via the one way.
acloco is offline
Old 03-15-2002, 01:57 AM
  #2269
Default Angle of the steering rods (Question)
Hi Guys, I need your Help.
I have just installed the new Low roll center mounts and the rods of the steering is too incline. This is my opinion. I thought that it will be better if i put the ball stud from the down side instead from the upper side of the sprindle? This way the steering rods will be more parallel to the ground..
Please tell me your opinion, because this way i think the ackerman angle has changed.
Thank you in advance,
Harris
harris is offline
Old 03-15-2002, 03:42 AM
  #2270
Actually, the outer wheel will free wheel when you are on the throttle in a turn.
Kaliboy is offline
Old 03-15-2002, 08:41 AM
  #2271
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
actually, the front only free wheels off power..on power the power is equal front and rear.....thence the better launch out of the corners...
Matt M. is offline
Old 03-15-2002, 07:12 PM
  #2272
wroops! Thinking too hard.....the OUTER wheel freewheels in the turn......as the distance travelled is greater.......sorry about that.
Sorry losi........but the one way works in the corners AND when off power.
acloco is offline
Old 03-15-2002, 07:20 PM
  #2273
Finally somebody got it.
Both front wheels spin at the same rate when on-power with a one-way; like a live axle.
As for the more "topend"....that is a new one, never heard that before. Don't really see how...unless the front diff you are running is slipping, which it shouldn't, but that would cause a host of other problems.
The one-way give more offpower steering, thus more cornerspeed. Always. The front tires will not scrub speed when you turn them. If you have the ability to drive the car with the one-way installed, it will be faster.
In some cases, the one-way is such a handful, the few tenths you gain by running the unit, go out the window if you have a couple bobbles in the run. The tight track v. open track thing is a myth. You pretty much always run a one-way on carpet(rubber), and those track are notoriously tight.
You often have to build a setup around the one-way, so the car has plenty of traction. I also suggest turning down you brake EPA...you cannot just slam on the brakes with the one-way...you will lock up the rear tires and perform a donut. The rear tires are the only ones braking, and with the weight moving forward, the rear tires will lock easily. You can use brakes with a one-way, but they should be properly adjusted, and the tweak/weight distribution of the chassis has to be spot on.
Personally, I've run a one-way in every sedan I've ever had. In some cases, running an unsuitable spec tire, sketchy track, etc, I popped the diff back in.
Good luck.
SirSpeedy is offline
Old 03-16-2002, 05:46 PM
  #2274
littledog's Avatar
Default Any Ideas
I've got the turbo 35 se,and I keep getting a hook batt connection
signal on the screen.This just is'nt on one batt.but all 10 of my packs.I could under stand maybe one or two packs,But ALL ten of them?!!
littledog is offline
Old 03-16-2002, 06:58 PM
  #2275
Was out running my car today and it seemed pretty planted except when making med- hard rights the rear breaks loose. Turning left no problem Running the Francis outdoor setup except stock P2K2Pro/24/90t, stock rear silver spring and stock tires(Sorex 36R and HPI X pats on way).
Any suggestions on what to check first? Don't like the tires and they don't fit the RPM rims I'm using too well. could it be one of the tires causing this?
MDM3 is offline
Old 03-16-2002, 07:10 PM
  #2276
Mad_Cats's Avatar
Sounds like your setup is a bit off, as in not equal side to side (like chamber or possibly a oil-less shock). Another possibility is there is something binding in the front of the car.
Mad_Cats is offline
Old 03-16-2002, 07:11 PM
  #2277
STLNLST's Avatar
Trader Rating: 32 (100%+)
Default Re: Any Ideas
Check your fuse in the charger.
STLNLST is offline
Old 03-16-2002, 08:25 PM
  #2278
littledog's Avatar
Default Thanks
But I figured it out.It was the battery power supply.It was below 9 volts.But thanks any way.
Old 03-17-2002, 11:23 AM
  #2279
Default one way vs. diff
so which is better for all conditions? depends on the driver and the car. in my tc-3, i run a one-way exclusively - i just could never get enough corner speed w/ a diff (of course, i'm talking about in relation to the other guys at my track). now, there are a couple guys that are smokin' fast w/ dual diffs. in my xxx-s, i've tried it w/ a one-way and it had alot of on-power steering, but didn't for work me at all, it seemed to twitchy. maybe if i spent some time getting accustomed to it, i'll be able to drive it. i'm currently running dual diffs, and i'm getting more corner speed than my tc-3 w/ a one-way. i have to admit though, the xxx-s w/ a one-way was faster, i couldn't drive faster w/ it. with the dual diffs in, my car looks "deceptively fast". what i mean by that is it looked slower on the track, but my lap times were better, and i think that is because i had better control over it. hence, i was able to drive more consistent laps (ie. on a track that pro-stock was throwing down 10.9-11.2 lap times, i threw down an 11.4 in the last 30 seconds of the race and had a string of 11.3's during the middle of the race - when the batteries and motor should be falling off a bit.)
i'm sure i'm going to try the one-way again, but for now and for me, the dual diff works best.
diesel31 is offline
Old 03-17-2002, 11:53 AM
  #2280
Ill Factor's Avatar
I tried something yesterday that really seemed to work well and gave me the extra on power steering I needed, I noticed my car actually pull away from TC3 when exiting a turn.
Setup is basically Stock except.
0 degree kickup
60wt front & back
Green Losi springs front & back
2mm droop front
4mm droop rear
4mm ride height in front
4.5 mm ride height in back
This set up works for me on a high bite asphalt track. You will basically need to use tires according to track temp.
I have also been fooling with some gearing ratios, for stock racing.
With a P2K2 Pro I have been gearing @ 30/100 in 64 pitch. This is a final drive ratio of 6.09. Now I know alot of you here run much higher ratios, but this really gave me a nice balance of torque & rpm.
If any tries this setup let me know what think of it or what you do to mke it faster
