Losi XXX-S
#2191
has any tried the matt franis graphie front bumper brace? I heard it breaks the front diff cover. If you hit something hard enough is this true?
#2192
Noticed most of the Losi drivers do not run the stock Fear body.Is there a big difference in aerodynamics that even a intermediate club racer would notice? Not legal?
#2193
Losi drivers do not use the Fear Body because it is illegal, not four doors. Only you would be able to tell if you can feel a difference in the car with different bodies.
#2194
Thanks. Forgot about the 4 door rule. I read somewhere where I heard it was topheavy.
#2195
Stock body
The local track where I can race doesn't run by any set of rules. So I don't think that the stock body will be an issue. I do plan on racing at some track where it may be. What body would you guys recommend for use on the XXX-S.
#2196
I personaly use the hot bodies strato.it's not too light and not too heavy.
Just my two.
Just my two.
#2197
are there any aftermarket springs that will fit the stock xxx-s shocks? what about the spring set (9 different rates, i think) for the TC3?
#2198
HPI spings fit, old Tamiya springs fit, new Tamiya's don't
#2199
I just realized that my setup wheels from my Tamiya & HPI cars won't fit. Who makes some good ones for a standard drive shaft?
#2200
Trinity Congos will fit, but they are 30+ lb springs.
#2201
thanks guys, for the tips on the stripped screws...and speaking of bodies, which bodies do you run, if i may ask?
joe.
joe.
#2202
thanks for the info i think i have old RS4 and TA03 springs somewhere.
#2203
anyone here have problems with the wheels binding while in full turn? im using non losi rims and my car seems to vibrate a lot while cornering, do you guys modify anything when using aftermarket rims like yokomo?
#2204
R/C Tech Founder
productnine: I run a '98 Accord Coupe body on my cars for club racing, and a Yokomo/Andys Stratus for real events.
#2205
