Hot Bodies TCX
#2461
from what i'm looking at, its the plastic part that came in the kit (at least to me)...IMHO, there's ain't anything too 'trick' on his car aside from the shock tower and knuckles
#2462
maybe these ...
However, they are aluminum stop-bar TC, with old sway bar holder Cyclone Moorespeed.
#2465
just a plain ol' dumb question...
how does it effect the car when you run the different FR suspension block? i l realize you can essentially change front track but running different blocks (like 3.0/3.0 will widen the front track), but what else does it get you??
I remember playing around with this on my old tamiya surikarn evo3, but never noticed any earth-shattering differences...
#2466
hello
i'm from france and this is my first post
i'm a new owner of tcx, my kit is coming at the end of the week
i have read this thread and i see only one problem with the car : the front cvd
do you think option part "67731 - POM Solid Axle Cup Joint" can preserve front cvd from being broken in race condition? the material seems to be a lot softer than original steel solid axle cup joint
i will run with rubber tyre and x12 5.5 motor
thank
thank
#2469
thanks
#2471
Would the 20t center pulley setup fit the tc if i get the appropriate belts for the tcx?
#2472
hello
thank
thank
#2473
Im guessing to fit the 1.5fr block you have to dremel it so the belt can run over it?
