Hot Bodies TCX
#2611
#2612
Mine got no issue. I even had to increase the tightness to prevent skipping.
#2613
I'm not sure I'd use anything thicker than 1k hence i think 800 is the other option I would use although I will probably get dot 4 just to try it out and see what it does. Do you know if yokomo do dot 1,2 and 3 and what the rating of these are?
#2614
I know a bunch of people have complained about slop in the steering system. I played with mine yesterday and was able to completely eliminate it with 4 small shims.
The first shim is a 4mm .02 thick on the steering post itself. It eliminates the up and down slop.
The other shims are a 3/16th shim I think. Very thin. If you look at the alum piece that connects the two bellcranks, there is a small lip that goes towards the bearing side. This shim fits around the lip and when bolted on, eliminates the slop there.
I will take some pictures today and post tonight.
#2615
3.5 FDR
What gearing combination should I use to achieve 3.5 FDR? RCGT
#2616
#2617
Bubblehead: (spur/pinion)* internal ratio= FDR.. so just do the calculations and you'll be there. I believe the IR is 1.95 for the tcx. Sorry i run 40 tooth pullies so my IR is different.
#2618
RCGT is a 17.5 blinky class. So a 9.5 would make it run slower than a stock mini cooper. I guess you thought he was asking for gearing for a 3.5 motor. RCGT at floyd would be miserable with that straight away.
#2619
#2620
a buddy of mine did that site, works from a PC or phone...handy little web app - click the link for FDR
he's also got a freebie for an android, if you got one of them...check out tigeryan in the andriod market
#2621
#2622
Dot 2 #800
Dot 3 #1000
Dot 4 #1200
Dot 5 #1600
Dot 6 #2100
Dot 7 #3000
Anyone else tried?
#2624
#2625
The TC has the heavy duty steel 44mm shafts.. and the TCX has the HPI pro-d 46mm steel shafts..
