Tamiya TB-Evolution IV >
Like Tree2Likes
Old 09-20-2005 | 01:10 PM
  #3121
jhigga15's Avatar
Is there any tips that I need or something that I should look out for?
Thanks,
jhigga15 is offline
Old 09-20-2005 | 03:58 PM
  #3122
Superdate's Avatar
Default battery holder
wanna ask a question about the battery holder on evo ms, if using isolated battery rather than stick pack, besides glass tape, what else can be use to hold the battery? cos if i am using the plastic holder come with the car, the battery might be able to move and hit the shaft in the middle or might be able to drop out of the car. thx
Superdate is offline
Old 09-20-2005 | 04:27 PM
  #3123
A friend of mine recently had this problem, grab 3 ball cups snip off the ball section, and use them as plastic posts screwed to the chassis, 2 on the outside of the battery, and one on the inside rear to keep the last cell away from the shaft drive cup.
Besercoe is offline
Old 09-20-2005 | 05:10 PM
  #3124
F. Alonso's Avatar
When I had my Evo4 ages ago, I used a Yokomo MR4-TC Graphite Battery bar as this uses the same dimensions as the Tamiya one but is extremely rigid and not flexible like the Tamiya one. You could tie a knot with the Tamiya one it was so flexible.
The Yoke bar fits on the existing Battery posts fine and works great. Never had a battery come out EVER.
F. Alonso is offline
Old 09-21-2005 | 07:07 PM
  #3125
jhigga15's Avatar
Will the battery slots on the MS fit 3700 or 3800's or will have Have to mod it?
jhigga15 is offline
Old 09-21-2005 | 07:12 PM
  #3126
JimmyMac's Avatar
Mine (eXpress 3800's) seem to fit on the regular EvoIV which is the same chassis as the MS. One thing to note on my 3800's... I did not heat shrink them which would make them slightly even larger.
JimmyMac is offline
Old 09-23-2005 | 12:10 PM
  #3127
jhigga15's Avatar
Just got it in the mail today!!! I won't have time to build it today.
jhigga15 is offline
Old 09-29-2005 | 08:08 AM
  #3128
jhigga15's Avatar
Did you guys put ca glue on the chassis like the book says?
jhigga15 is offline
Old 09-29-2005 | 08:17 AM
  #3129
berger's Avatar
I sanded and smoothed my chassis and top deck and sealed it, remember if your using tape to really round off the slots where the tape passes through the chassis otherwise it can cut through the tape.
berger is offline
Old 09-29-2005 | 09:11 AM
  #3130
jhigga15's Avatar
Do I need to seal it or can I just leave it as is? I have never done anything like that and I don't want to mess up the look of my car...
Just got my clear blue gear covers!!!
jhigga15 is offline
Old 09-29-2005 | 09:31 AM
  #3131
jeffreylin's Avatar
First of all, you must file the slots down if you were to use side by side pack. Otherwise the chassis will cut through the battery and cause a short and fire (it's happened to me, no kidding). You also need to file the battery tape slots smooth or the chassis will cut your tape during a race.
As to sealing the chassis, again I think it's important. You are running a electric car and the carbon fiber chassis conducts electricity. It's just a good idea to seal it. Plus I think a sealed chassis prevents a lot of glitching problems and protect the chassis from splintering during crashes.
jeffreylin is offline
Old 09-29-2005 | 09:47 AM
  #3132
jhigga15's Avatar
Very good points...So do I do all of this filing and then just run CA glue along the chassis and barrery slots? How do I seal is and what should I use...This is not my TB02...I really don't want to mess this car up
jhigga15 is offline
Old 09-29-2005 | 10:03 AM
  #3133
jeffreylin's Avatar
Yes just use CA around all around the chassis and around all the slots. Q-tips work well for the application.
Old 09-29-2005 | 10:08 AM
  #3134
Just file the edges of the chassis & top plate to get the sharp edges off. On the battery slots you will want to take your time and test fit a pack quite often to make sure you get the batteries to sit flush with the bottom of the chassis, but not sticking through. Once you get all that done, then use a Q-tip and apply thin CA to all of the areas you just filed. Take you time and it will come out good. I think Calandra has a how to article on their site about chassis prep, but I can't get their site to load right now. Good luck and remember to TAKE YOUR TIME.
dway100 is offline
Old 09-29-2005 | 10:53 AM
  #3135
jhigga15's Avatar
I feel much better about this now!!!
jhigga15 is offline
