-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
MUDVAYNE 08-24-2005 07:27 PM
Been there done that, not much there.
factory racer 08-24-2005 07:58 PM
yeah im in the same position im looking where to buy a cheap but new L4 i also checked ebay and they dont have any there
thanks
Mike
Still Bill 08-24-2005 09:05 PM
It's almost that time of year when my TWO L4s shine like gold...he, he...
factory racer 08-24-2005 09:36 PM
do you want to sell one of those pieces of gold???
:lol: :lol: :lol: :nod:
thanks
Mike
P2 08-24-2005 09:42 PM
Originally Posted by davidl
I would like to give a plug for the IRS Rugrat conversion. It is virually identical to the CTC T Force. Actually the RugRat might have been release first, but I don't remember. But this vehicle is one of the best kept secrets in 1/12 scale.
I have to agree with you Mr Lee, after my horrid performance at this years Snowbirds, my Rugrat has since been dialed on asphalt and carpet. :D At my local track the Rugrat is probably the most popular car but not too many people talk about them in this forum.
Paul
jrrc 08-24-2005 11:21 PM
davidl,
Do you have setup for the rugrat for 12th stock/carpet? Looking for a starting poinr for vegas. Have you noticed its better on tight tracks with its shorter wheelbase?
CarlosG. 08-25-2005 05:37 AM
Does anybody know who sells a whole complete screw kit for the 12l4? And possiblely have a link to their sight?
Fuzzy 08-25-2005 06:38 AM
Check with RC Screwz. http://www.rcscrewz.com/
Still Bill 08-25-2005 07:09 AM
If you want the standard aluminum 12L4 screws, try AE. I believe they have it in a complete package.
P2 08-25-2005 07:42 AM
Originally Posted by jrrc
davidl,
Jim, you have PM! I'm not davidl but should get you started.
Paul
davidl 08-25-2005 08:51 AM
RugRat Setup
davidl,
First, I haven't noticed that the wheelbase is short. How are you comparing it to say that the wheelbase is short?
Second, my current setup is in preparation for a high bite track. That being said, I am working with hard purple front tires and white rears. The plan is to move to grey rears when the traction comes up.
*caster - all shims forward on the AE dynamic strut, 10 deg reactive
*camber -1.87 deg
*center shock - silva, 25 wt AE oil, AE blue spring
*king pin damping - Losi heavy hydradrive, .018 front springs
*Tee-Plate - Power Push .079 thick, tweek screws to the rear
*Damping tubes - Losi heavy hydradrive
*Steering servo set flat with Kimbrough med servo saver, IRS elevated pivot balls on spindles to level steering rods preventing bump steer
*Lower front suspension arms (.060) with .045 shims to put front suspension at same elevation as used on the 12L4. This sets front roll center.
*IRS rear ride height adjusters, 2.5
*Front tire 1.75 dia start
*Rear tire 1.85 dia start
*TQ8 Pro Plus traction compound
*Parma Speed 8 body
*Steering servo Airtronics 94145
*No receiver pack
*IRS lowered rear pod top deck and new side plates
*IRS rear differential w/large rings and Kimbrough gear set 6.73 wide
*Front track has one .020 shim inside each front wheel
*BSR tires and wheels front and rear
This is for stock motors. Still working on something for modified. Hope this helps.
losixxx 08-25-2005 08:55 AM
DavidL,
where do u have your battries at?
JPH Racing 08-25-2005 09:21 AM
DavidL: I'm a little confused by this part of your post. Can you explain it in a little more detail please? Seems .060 - .045 = .015 lower than stock? Where does this set the roll center compared to stock?
Thanks!
Jake
[email protected]
losixxx 08-25-2005 09:35 AM
Paul
what is so great about the irs i cant get mine to handle exactally the way i want . Ive even switched to assoicated dampner plates.
Let me know
jrrc 08-25-2005 11:16 AM
David,
I'm comparing it to the L4. The Rugrat is couple of mm's shorter, while the Yokomo is a couple of mm's longer.
Thanks for the info.
