-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
JDXray 01-27-2005 08:30 AM
Re: Re: 12L4 Mod
Originally posted by lem2
Yes, it can be done! I did it on my L3, more or lss youwill use the same parts, I used the ones from CRC. Look...
Hey Lem, quick quesiton. On your L3 arent the damper tubes backwards? Are they supposed to be going the other way. I htink you might have put the piece where the body post and damper tubes on wrong backwards. I might be wrong. :rolleyes:
Nexus 01-27-2005 08:51 AM
Being new to 12th scale I'm not sure what people run...
What are the more popular servos to run in 12th.
Just looking for something nice with a reasonable price tag.
KO
JR Racing
Futaba
Airtronics
not a fan of hitec.
Thanks.
brianrice 01-27-2005 08:59 AM
All of those companies make a good servo.
It's all personal preference.
I prefer the KO 947 or the newer 949.
JDXray 01-27-2005 09:09 AM
KO
JR Racing
Futaba
Airtronics
not a fan of hitec.
Thanks.
The KO's are great. I am using a Futaba 9602 which is great. Or you can go digital with the futaba.
Crashby 01-27-2005 09:11 AM
Originally posted by crimson eagle
Revzalot,
Yes, I like it. Damping doesn't change front to back, tube are easier to deal with and that post is a pain in the rear. I've also bee making some carbon - carbon tubes, way better than the plastic or aluminum ones.
Chris.
Have you finished my tubes?!? Quit playing around on this forum and finish my dampener tubes!!:lol:
CypressMidWest 01-27-2005 09:51 AM
Originally posted by EricF
Link cars obviously work on asphalt as well as carpet, but it would seem to me that 't' bar cars are eaiser, faster to set up on asphalt.
As I found out the hard way when running a link car on asphalt (or any surface) make sure your starting out with new tires. Do NOT use tires that you may have had from last season. They just don't seem to work and you keep chasing a car that doesn't handle.
E
That's odd because I always found my link car FAR EASIER to set up for asphalt because I could tune the roll-rate and dampening, and the fore and aft rate and dampening, independently. T-bar cars always seem to be about compromising, because your whole suspension revolves around that hunk of fiberglass. Link cars are more sensitive to changes in shock oil, and spring rate than t-bar cars, so I guess for some that may be difficult.
JohnB 01-27-2005 09:52 AM
Originally posted by picco007
John,
I had the same problem when I changed to a damper tube car from the friction disk car. What I had to do to get the car to work better, I had to change the damper tube syrup a few times and when then found what we like here on asphalt. I was using the corally blue stuff (don't know what thickness) and it was fine.
Yes sir. The oil or grease changes everything.
I think I like the damper disk better is they effect more of the steering feel, this is carpet racing. With tubes it seemed to get the steering I wanted I had to take away rear traction with shock oil and stiffer springs.
kh15 i noticed alot of pros dont use those friction plates?
I think it's the other way around. Masami won the worlds and Blackstock has won about everything once. They both use disk. There are starting be more tube cars though.
I think it's good to know what both setup's do and be able to switch between them as option. The more you try things, the more you learn.
take care
john
crimson eagle 01-27-2005 09:53 AM
:D
Hi Crashby,
I plan to work on some tubes on Friday actually, I'm probably going to do 4 or 5 standard sets, then work on some sprung prototype sets, then if I get time (unlikely) I'll work on some titanium piston sets. If I can get these ones down to a reasonable production time (instead of the 4 hours it took to make my set) I may offer those too. But I do have your name on a set.
I really want to try a sprung set on my L3 to see what it does, maybe it will liven the hadling up a bit.
Chris.
crimson eagle 01-27-2005 10:03 AM
Most recently I have been using 50,000 silicon in my tubes, seems to be pretty good but in my tubes I have tried to maximise the length of the piston in the tube for the best damping effect. I'm interested to hear what everyone else is using and to what effect?
Ian Shepherd 01-27-2005 11:41 AM
Originally posted by MR JOLLY
Wish i could get to kent:eek: no you would`nt scotlands far prettyer
Anyway the club here is having it`s first meet for 1/12th on march 18th, that will be the first test run for them:weird:
next thing is this
Corally TC2 (Jack the Gripper) Silver can - pink writing (13779)
LRP Top Traction (Blue Factor) White can - blue writing (6501)
Orion Street Juice (TC Traction F1) clear bottle - purple writing (44101)
Orion Foam Juice Formula clear bottle – yellow writing (44105)
CS Grip Tyre Conditioner – High Grip clear bottle white label (C6400)
- Or short tin can - white and yellow label (C6400)
The packaging of the CS addative changed -same part number, two types of container
In the UK most people use either:
or
CS Grip Tyre Conditioner short tin can - white and yellow label (C6400)
Spashett prefers CS
I have even used Jack the Gripper on CS27s :D
Not too sure on the others...
"Jack the Gripper" What a cool name, second only to Novak's Rhino charger "Nothing charges like a Rhino" :lol:
John_S 01-27-2005 11:45 AM
in scotland 90% of people use the lrp compound
Crashby 01-27-2005 11:47 AM
:D
Hi Crashby,
Chris.
You Da Man!!!
Ian Shepherd 01-27-2005 11:47 AM
Cool, I have seen a few people use it but not tried it myself
revzalot 01-27-2005 02:12 PM
12l4 observations
I've done some test runs at my local indoor racquetball court and foud out the aluminum screws are sticking out of the chassis more than before. They expand more due to friction and heat. All the holes on the chassis will have to be countersunk. I'm using a drill bit and sanding cone to countersink.
litespeed-dom 01-27-2005 02:38 PM
Due to friction and heat? How's the possible? Is the chassis dragging on the ground? I've never heard that aluminum screws will expand on a chassis before.
Dom
