-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
JJ187RC 10-24-2004 06:04 PM
Doug that would eb great since I am running your car. Do you have them listed on your webpage?
DPowell 10-24-2004 06:21 PM
They are not on the webpage but you can send me an e-mail and we'll get you going.
D.P.
ALBERTO 10-24-2004 07:54 PM
hey guys I'm a bit new to 1/12 racing, but i must say every bit of advice you guys have given me has worked awesome!!!! THANKS!!!! Now for some more questions. I run a L4 on a tight carpet track and i was wondering which spring I should use in the center shock? ( currently I am using green). I also was wondering has any one used the spring steel t bar? I have seen it on the IRS web site but dont know if there any good,or what application are they good for. Thanks again :D :D :D
Adam Hartzell 10-24-2004 07:57 PM
pucho--That top pod plate and chassis brace look real familiar:sneaky:
lazyboy 10-24-2004 08:15 PM
what do different t-plate thicknesses do to a 1/12 scale on the rug???
lazy:confused:
ALBERTO 10-24-2004 08:38 PM
durability????
pucho 10-25-2004 03:38 AM
My Friend runs the Q12 so he convinced me to run the rear pod plate and tube setup.
Speedie 10-25-2004 04:26 AM
Lazyboy here is a good site with info about associated cars.
http://home.comcast.net/~mlufaso/rc/
Might answer some of your questions
pink pac man 10-25-2004 06:04 AM
Originally posted by lazyboy
its 8minutes on 4cell, just pick up some high 1.17's from hurrican or fukuyama,team1,etc...
my club runs 5 mins.........
puncho ......sweeeeeeet what brand is it [sorry im not 1/12 scaled YET]
pucho 10-25-2004 06:33 AM
It's and L4 with a PRC top plate and cross brace so that tubes could be used instead of the plate setup that comes from the factory.
Dr Smooth 10-25-2004 11:31 AM
Spur
Hi all, what spur should I use when running stock? do i use a smaller spur 96 or 100 what i understand is the smaller spur spool up faster with the stock is that what the stock racers use
i am not shore, to me the car was not faster with using either.
fatdoggy 10-25-2004 11:33 AM
Dr Smooth - You generally adjust your spur as your tires get smaller. Start with a 100, then 98, then 96. You could just start with a 96 but you won't have as many rollout options.
litespeed-dom 10-25-2004 11:46 AM
I wouldn't go with a 100.... a 96 is decent.... the smaller the better since with the smaller spur, you can jam a larger pinion in there. For stock racing... at least for us, it's finding the biggest pinion possible.
Dom
lazyboy 10-25-2004 01:32 PM
thankyou, that answered most of my questions:)
lazyboy
EngTat 10-25-2004 02:40 PM
can someone tell me whats the diffrence between 1304 - Carpet Knife 3.2R and 1303 - CKV3.2 Team Red Bloody Knife and which is newer??? .thanks
