Re: Hot Bodies 12th scale bodies
Originally posted by barrys The final IFMAR approved body list is out for the upcoming Worlds. Absurdly enough, defaults like Proto Speed12 and Parma Speed 8 aren't available. Luckily the CEFX and the Trinity Speed 9 are. Has anyone had any experience with any of the Hot Bodies for 12th scale (they are IFMAR approved) http://www2.towerhobbies.com/cgi-bin...P?&C=CHB&V=HBS take care john |
how do the trinity speed 9 and cefx bodies compare on asphalt?
Looks to me like CEFX and CRC are the best bet? Both unknow to me but you don't have a lot of choice. The new CRC looks very good. Josh has shown the CEFX is good.
Does IFMAR allow the use of wickerbill's (sp?)? Always an easy fix for rear traction. Here it is: http://www.teamcrc.com/php/images/st...60-b-480sm.jpg |
Originally posted by MDawson how do the trinity speed 9 and cefx bodies compare on asphalt? |
Originally posted by CypressMidWest The Trinity body works pretty much like the Parma, (since it's almost an exact copy). |
the CEFX is considered by many to have more steering than the Speed 9
Obviously, it will be what Josh will be running |
Can someone tell me 1 thing.....for those MOD 12th ppl, they used those tiny little receiver pack to max out the batteries pack for full 8 minutes.......what size of batteries are those?
Are they 1/3 AAA (like 280mah capacity) or something else...? Thanks.......... |
150mah nimh cells.
i found these on ebay, they finished a couple of days ago, but he still had a load left, try emailing him
click here |
Originally posted by Adam Hartzell 150mah nimh cells. Like 2/3A, 1/3AA. 2/3AAA.....etc Those are the weird size.....just don't know what they are. |
i'm thinking of buying a quad 12 conversion, does this conversion make a huge difference too the L4
Originally posted by jas1 i found these on ebay, they finished a couple of days ago, but he still had a load left, try emailing him click here Believe it or not, beside my 12th scale........I need some of those to POWER up my AMB personal............I have a micro that has no 2nd input from the receiver, so I have to find a external power for the AMB- personal............can anyone tell me what is the minimum voltage that AMB required...? 4.8V or less (or more)? Thanks |
Originally posted by jas1 i'm thinking of buying a quad 12 conversion, does this conversion make a huge difference too the L4 |
cant you just use a y lead, gives you 2 outputs from one
Originally posted by clinttredway in a word yes! its more adjustable and easier to drive... and the best part is no tape! |
| All times are GMT -7. It is currently 08:10 PM. |
