Re: spur gears
Originally posted by smyka hey guys for those of you looking for light weight spur gear try PRS they are qulity gears machined so they run true and they are light weight for those of you running large diff rings order the oval gears and for small ring people run the touring gears i have been running theise spurs gears and pinions since snow birds last year and this is what they have done for me tq'ed and won the birds tq'ed the nats and won the indoor champs all with the same gear so they last a long time I have to agree about the PRS gears, but who is currently selling the PRS spur gears? I know RC4less has 108 and 88 tooth gears and other than that I have not been able to find any on the net. Thanks, Mike |
im currently using 48 pitch gears in my rc12l3 and theres no room for mesh adjustments. i can barely turn the motor coz it binds with the t bar. will a 64 pitch gears free it up a little bit ?
dakrat - Almost everybody runs 64 pitch in 12th. Not sure why all this 48 pitch stuff is coming from.... You can try grinding away some of the T-bar so you can get the mesh right with your 48 pitch stuff.
Originally posted by rayhuang At th Champs-one of the only changes I made all weekend was ditching my stock center shock and building up a new Silva shock with the new plastic bushing inside. I actually bought it direct from Dave who was right above us. So much smoother than my original shock and imrpoved greatly over the original Silva shock which could bind. Car felt more consistent with it and my laptimes dropped the run after installing it. I dont know if that was a fluke-but it did seem to help. Did you go with the hardcoated one? I only know IRS website sells the Silva stuff and not quite sure if they are carrying the latest Silva shock. Besides IRS, where would I find the new Silva shock??? Dom |
Damper tubes - springs or no springs?
What's the difference/benefits of running springs or no springs with tube cars?
Dom- How's the Monkey working for you? |
Re: Re: spur gears
Originally posted by Michal101 Hey Mark, I have to agree about the PRS gears, but who is currently selling the PRS spur gears? I know RC4less has 108 and 88 tooth gears and other than that I have not been able to find any on the net. Thanks, Mike You can go ahead and purchase them directly online. Hope this helps. |
Re: Damper tubes - springs or no springs?
Originally posted by stumper1 What's the difference/benefits of running springs or no springs with tube cars? Dom- How's the Monkey working for you? The Monkey is amazing! I'm suprise not all Rain guys are running one, you guys all should! On another note, Ron Smith from R/C Plus will be running my CEFX (your old car) this weekend at Tri Cities. Dom |
Originally posted by fatdoggy dakrat - Almost everybody runs 64 pitch in 12th. Not sure why all this 48 pitch stuff is coming from.... You can try grinding away some of the T-bar so you can get the mesh right with your 48 pitch stuff. will it affect the t bar's effectiveness? |
Dom-
Cool. I've been thinking about trying springs in my CRC tubes. I've also been eyeballing the Monkey!!! Maybe soon:sneaky: Did you ever run the CEFX? What did you think? |
I'm not quite sure if the ASC front springs will fit on the CRC tubes....
Actually, I never did get to run the CEFX. I got the car from you during the gas season, so I didn't have the time to run down to Salem to run it and test it. So I let Ron have it since he owns the shop/track and had the time to test it out. He and Chad Kramer both runs it and like it a lot. Chad was stupidly fast on Saturday, on pace to break track record by 2 laps in the Main. Dom |
Dom,
Actually, Brian figured out that they fit perfectly INSIDE the CRC tubes. What size spring do you use? |
Originally posted by dakrat will it affect the t bar's effectiveness? |
Originally posted by stumper1 Dom, Actually, Brian figured out that they fit perfectly INSIDE the CRC tubes. What size spring do you use? |
Originally posted by stumper1 Dom, Actually, Brian figured out that they fit perfectly INSIDE the CRC tubes. What size spring do you use? Start with .020 first. Dom |
Best Batteries For 1/12 scale
1/10 scale on road racer looking to get info on what to look for when buying batteries for 1/12 road course racing.
Any tips would be great. Thanks Was considering the fusion or surge batteries . |
| All times are GMT -7. It is currently 01:02 AM. |
