1/12 forum
What I read is that the motor wind will be caped at 6.5, but I don't see any blinky rule.
Anyway IFMAR will stay at open mod. I like to believe that this step will bring more people
to run 1/12 mod, but on the other hand why these people not running now the 6.5 motors in 1/12 mod?
I can see why this would be proposed but I don't think it will have the intended effect of increasing modified turnout. A tested, tuned 6.5 turn open ESC setup would still be screaming fast, so fast that I would argue it would fall under the statement "beyond the capabilities of all but the very elite to be able to control and race." Add to that how all of the sudden your ESC choice, software choice, motor, battery, and all of the other factors that you don't worry about become relevant to modified racing again, instead of picking a color and go.
Not my problem though, I live in America.
It will be easier to control than the current mode of 3.5T open esc
Not sure 6.5 open esc will draw more entries though, it's still too bloody fast for most drivers
Having said that. the BRCA crew currently have the strongest contingent of 1/12 racers in the western world
So I support this fully, and would be up to give it a go
Short of hand out packs, not sure how this can be enforced?
I loved the old days of gearing for time but, to do that now days would be a death nail for 1/12th.
Most 1s batteries sold today are 7000 to 8000 mah rated. A required 4200 to 4400 mah battery for one class only wouldn't go over well with racers or manufactures .
A gear for time race would create a battery war, battery of the week, cheating . It's just not worth it.
I don't miss the need for 5 awesome, fresh, battery packs for a race day or the need to rebuild your motor every run.
I would think the labeling on the battery would be a dead give away. tamper evident case tape from the manufacture where the roar label currently is. Granted if someone is determined to cheat they will. Could be as simple as Cycling the battery after a suspicious or record setting run and seeing how many mah it takes to Discharge/charge. obviously too much hassle for club level racing. However for higher levels of competition Cars can be "teched" its not hard to imaging if you had a 4400mah battery and put 4800mah into it after a 8 minute run. Maybe there had been some tampering. and I'm sure you could also argue that a 7000mah battery shoved in a 4400mah case would provide a better voltage through a run. But again, can be cycled after a run to determine the battery capacity.
(I know VTA limit the lipo capacity, but to be honest that is a waste of time as the over a certain capacity the start to weigh too much and unbalance the car)
At the least the motor is easier to check if there are any doubts
2991Likes
