Like Tree2991Likes
1/12 forum
Old 01-13-2011 | 06:13 AM
  #35311
theisgroup's Avatar
Originally Posted by zipp
Hey guys,
I'm new to 1/12, having just got a HB 12X
I intend to run 4 cell Nimh, with brushed 27 turn motors.
Could anyone with experience running this setup please recommend me a rollout?
I have searched this forum, as well as some setup sheets. Seems like something in the range of 42-48mm (1.65"-1.89") is quite common. Am I on the right track?
Thanks!
it has been a while, but if memory serves me, you are in the ballpark. I think we ended up around 50mm at the big races.
theisgroup is offline
Old 01-13-2011 | 12:24 PM
  #35312
Smile
Bought the balance tabs to check weight distribution on my link2 and it was considerably off.. Added just enough weights on one side to balance. My tweak even came out perfect via both wheels lift at the same time. Thanks to everyone who helped! Anything else I can do to bring my car one step to dialed?
artoftatt2 is offline
Old 01-13-2011 | 08:50 PM
  #35313
Default easy question here:
i have a fairly easy question: what's a decent tire truer to get without breaking the bank? i'll probably only be cutting a set every couple of weeks and am only running stock...also i already have a power supply capable of 30A so i dont need an AC truer...
anthonyscardina is offline
Old 01-13-2011 | 09:40 PM
  #35314
rc_square24's Avatar
I have a manual ofna truer and its pretty good for 120, or for around 200 you can get an automatic Integy heard they're pretty good too.
rc_square24 is offline
Old 01-13-2011 | 11:06 PM
  #35315
My 3racing tire truer does a good job, good value for money.
Quante is offline
Old 01-13-2011 | 11:57 PM
  #35316
Default asso. rc12L3
can anyone post pics of a rc12L3 using a 1s battery including electronic setup
vintage boy is offline
Old 01-14-2011 | 05:26 AM
  #35317
CFR's Avatar
CFR
UK 12th Nationals Live
next meeting is Plymouth on 15th & 16th January[/QUOTE]
In an effort to keep 12th scale racers and followers up to date and in the loop with news and results, the national series will now be covered online.
From the Tamworth national onwards you'll be able to visit pages on Facebook and Twitter to see what's going on if you're not at the meeting!
On the facebook page there will be round by round updates including images of the qualifying lists as well as notable occurrences and things that happen worth mentioning. Following each meeting you'll also be able to see photos, videos and reports from the event.
To access the facebook page, Click Here
Twitter will be used in a similar way, but due to its more basic nature it'll be limited to short text updates on the movers and shakers in each round and the finals.
To access the Twitter page search for '@BRCA12thScale'
CFR is offline
Old 01-14-2011 | 05:48 AM
  #35318
20 SMOKE's Avatar
you can get a cobra track side cheap,got mine for $40.it uses a 4cell for power
20 SMOKE is offline
Old 01-15-2011 | 02:00 PM
  #35319
Pit-racer's Avatar
Where can I find a conversion kit for my sp12m corally? I want to change the old pod into the shock damper.
Pit-racer is offline
Old 01-17-2011 | 07:52 AM
  #35320
CFR's Avatar
CFR
Shepherd line of 1/12th scale tyres announed on redrc
so how many companies are there doing 12th tyres now?
CFR is offline
Old 01-18-2011 | 02:16 PM
  #35321
Bret13's Avatar
Best bet is to look on corallys site and see,not sure about the 12m though,probably the best thing to do is to just get the 12x or go for The newest one the 12sl,amazing car,I got one my self and setup are easy on it.
Bret13 is offline
Old 01-18-2011 | 03:21 PM
  #35322
RedBullFiXX's Avatar
Those look like the lightweight Exceed with black wheels.
If so, not the best wheels out there, by a long ways...
The new TRC Prime tires look interesting.
RedBullFiXX is offline
Old 01-18-2011 | 03:42 PM
  #35323
t4m1y4niac's Avatar
is it possible to upgrade my 12R5 to 12R5.1??
t4m1y4niac is offline
Old 01-18-2011 | 05:51 PM
  #35324
Does any one know of any company coming out with a yokomo style wheel in black for 12scale
Lizardboy76 is offline
Old 01-18-2011 | 06:05 PM
  #35325
wingracer's Avatar
Get the yokomo's and dye them.
wingracer is offline
