1/12 forum
I bought a pack of 10 rear bearings to carry in the spares. My son was breaking one every other weekend when he first started. I noticed that it often came from side slapping the wall in the sweeper at the end of the straight. So I started putting an o-ring between the stack of 1/4" axle spacers on the left rear of the car. If your car has enough space on the right side, you could do that as well. He can now make it a whole season or more on one set.
I too use o-rings as track width spacers on the rear axle to cushion the rear bearings from side impacts. It works great. On thing though - I don’t ever let the o-ring ride directly on the bearings. I put a thin metal shim on first so there’s no chance of the rubber rubbing on the bearing cage under compression.
My first day of practice with the car was rough to say the least, and I had some gnarly tumbles as I got more confident and pushed it. I can't say I'm too surprised, now that I think of it.
I'm back with more questions after racing yesterday
I seem to be dealing with a little more fade than most on race day. Towards the end of the main I'm definitely losing time compared to a few of the faster drivers. I've got a Protek 8800 LiHV, Hobbywing XR10 1S, 17.5T G4R, and my rollout is right around 89mm (65/45, 41.0 tire). Car comes off the track after a heat with a motor temp of ~150 degrees. My litmus test is someone I had a very close race with pulling away from me in the end, thanks to having what looked like more power, with the same chassis and electronics setup save for the battery. They're running the new CRC 150C cell. Can a modern battery really have that much impact? I'm operating on the assumption that, like, 3 companies make all of these batteries and it's just different stickers and cases.
If not, where should I start to look to help reduce fade throughout the main? Right now it seems I'm gaining roughly .3-.5s in average lap time by the end of an 8 minute heat.
A battery can absolutely make that much of a difference. While you're correct in assuming there aren't that many actual manufacturers of batteries out there, you get what you pay for in terms of battery chemistry and quality control. The current EAM packs seem to be the industry standard, followed by the latest CRC packs.
The other thing to play with is your motor timing and gearing. You'd be surprised how much a couple degrees less timing and one or two more pinion teeth can affect fade while not reducing overall speed.
The CRC 7500 150c batteries are very good. The two I have show .8-.9 ir. A friend who recently purchased the same battery is getting .7 ir. It being $30+ cheaper than other top batteries is an added bonus. Regarding fade, the batteries remain strong with only a .1-.2 second drop off at the end of the run.
I've tested a few different 1s batteries with the same case design and they performed virtually identical under a 40-amp discharge, giving some credence to your theory about many of these coming from the same source (CRC, EA, Tekin, eXcelerate, Fido, etc.). I'm not sure who makes the Protek batteries, but they are certainly different than the others I mention simply based on the orientation of the +/- and size of the terminals. They look very similar to a Reedy.
It might be the battery. I'd be interested to have you and the other racer put each of your batteries on one of your chargers after the race and compare voltage and then do a charge from that point to see how many mAh go back into each of your batteries. If you are running the same motors/timing and rollout, it could be that his driving style is a little easier on power consumption and at the end of 8-minutes he has just a bit more voltage than you do. On a 17.5 motor, a 0.1v difference in voltage is going to translate into an RPM discrepancy of about 250-300RPM at the motor. If he's willing to swap batteries for a run, try that.
This is a pretty good idea, and next time I actually plan to try and borrow a battery for a heat, just for the science. I just checked my battery from the main yesterday, and it’s sitting at 3.9v. That seems barely off from a full charger of 4.2v, but I could be very wrong.
Just remember, advice is always a guide, and VERY rarely is it a definitive answer. Don't be afraid to experiment and try new things.
I typically bring the car home and put batteries in storage the next morning. We race a lot of classes, even on club nights, so I usually don't get home until it's very late. I just had intentionally left this one so I could measure it and record voltage. I was always under the assumption that overnight wouldn't be a battery killer. Good to know I was wrong! I discharged and recharged at 20A to get it hot and IR dropped to about 1.7ohm... so not amazing but seemingly acceptable?
As far as motor setups - it just so happens the entire podium was running XR10 1S, 17.5T G4R motors, and 65t spurs- one MetriCKs, one CK25AR, and an A12WC. Closer comparison than most, but like you said, still not perfect. I'm not sure of everyone's tire diameters and motor timing.
I ordered a CRC Rocket fuel battery, and I might get the EAM cell to try as well. Next I'm at the track(won't be for a few weeks as I'll be traveling) I'll play with dropping timing and seeing how motor temps and lap times change!
1.7mohm on a warm battery on the Toolkit charger (I believe that is what I saw you were using) is... not good. For comparison, my M8D shows 0.5 - 0.7 on all of my fresh 1s race packs. My iCharger on the same packs shows 0.8-1.2 mohms.
Don't overlook SMC. From my testing, it was the only battery that stood out, holding 0.05v+ higher voltage across a 40-amp discharge cycle. I do have a brand new CRC 7500 arriving today that they are touting as "the best 4.0V numbers they've seen," so I'll be comparing that against my SMC, Fido and Tekin batteries.
Yep, ToolkitRC M8 and M8D chargers. I didn't know they typically read lower than iChargers. I considered it to be okay because my good Motiv packs(back in, like , 2018) never read below about 1.2 and they were the punchiest I've ever run. Relative to your findings... this Protek pack has more than double the IR. That's pretty bad. I'll be interested to see what the CRC reads when I get it. I did look into SMC, but they only have a single clearance 1s battery on their site and are very clear that is has subpar specs compared to their last batch.
Share your findings when you test those batteries! I'd definitely be curious to know.
2991Likes
