1/12 forum
so if I am seeing this correctly, you have a wire bundle that moves with the rear pod, and it doesn't seem like there is an additional loop between the battery and motor.
this would seem pretty free in roll, but what moves when the shock compresses?
Nice looking car. However, having esc right at the center of car under a cf plate will be a dangerous idea in my local track , we run 4.0t turbo at outdoor asphalt track as hot as 55 degree Celsius on the ground. Heat is the major issue here.
Well there is about .5mm of chassis under the esc. Not sure if that helps?
http://www.reflexracing.net/Team-Pri...et_p_2232.html
The best replacement shock for almost all 1/12
I just received and installed my new Team Prime shock on my 12R5. Very nice piece and installed smoothly. I know my AE springs will work with this shock, but I'm curious if anyone knows what the specs are on the spring that it came with. It's black, and feels a bit softer than the AE blue spring I usually run. The instructions are in another language and I can't find any info online.
http://www.reflexracing.net/RSD-12th...et_p_2096.html
I know the springs they sell by themselves are black with a spot of color at one end to identify them. Is your spring solid black or is there a color on it?
Did a few more videos.
Kyosho 1/12th Front End Setup System Unpacking
https://www.youtube.com/watch?v=dIdyxxnoHLQ
Using the Kyosho 1/12th Front End Setup System
https://www.youtube.com/watch?v=yqAMdYSRSpo
Team Prime Damper.
https://www.youtube.com/watch?v=ecOrYCDGf2c
Morotech X-Shock Springs.
https://www.youtube.com/watch?v=6M8IKKhGNcg
TKO Differential Rings Review
https://www.youtube.com/watch?v=blKIwSGpDoc
Team Prime Damper.
This is the video for "Using the Kyosho 1/12th Front End Setup System":
ED, two are the same video.
I fixed the url link in the original post.
hi guys,
i am trying to replace my 12R5.2 front lower arm with the xenon vss, well today i found out that i need the bushing (opt-0076) after i try to put it on today.
where do you guys buying the spare xenon parts other than TQ(out of stock) and Reflexracing(none)?
thanks.
thanks.
hi guys,
thanks.
thanks.
2991Likes
