Like Tree2991Likes
1/12 forum
Old 03-10-2010 | 01:26 PM
  #33721
Mark506's Avatar
A flat servo over a angled servo will produce what....? A little more Camber gain, and a bit of a different ackerman feel?
Mark506 is offline
Old 03-10-2010 | 04:18 PM
  #33722
Default gen 12xl ?
i have gen xl i ran on carpet. how will it work on asphalt or do i need a Tbar car and witch one?
thnaks ronzo
ronzo is offline
Old 03-10-2010 | 05:24 PM
  #33723
CypressMidWest's Avatar
Mark, Generally the steering feel is more immediate off-center with a flat servo. Servo flat set-ups also have a lot more bump-steer than angled set-ups. The bump-steer actually adds mid-corner steering, but can make the car a little inconsistent on bumpy tracks. Pulfer has been running servo flat, I've been running angled. It's a personal preference thing. Try it and see what you think.
CypressMidWest is offline
Old 03-10-2010 | 05:45 PM
  #33724
thnaks ronzo
The Gen XL will work great on asphalt. Depending on how well prepped the track is, you might need to go one step stiffer on front spring, and step softer on the side springs and the center spring.
dumper is offline
Old 03-10-2010 | 07:39 PM
  #33725
avs's Avatar
avs
that's interesting, i have been struggling with a very high bite indoor asphalt track. is this the situation you meant would benefit from stiffer front and softer rear?
i was going stiffer and stiffer front and rear to get more linear grip. what would you suggest with the gen XL layout?
avs is offline
Old 03-11-2010 | 07:17 PM
  #33726
W.E.D.Jim's Avatar
In case any of you are interested in a custom painted 1/12th scale body, this one just came available today.
...Jim
W.E.D.
Get Faster Gear
www.wedjim.com
W.E.D.Jim is offline
Old 03-11-2010 | 11:31 PM
  #33727
...Jim
W.E.D.
Get Faster Gear
www.wedjim.com
PM sent
stical is offline
Old 03-12-2010 | 08:57 AM
  #33728
dumper do you have a starting set up for asphalt?
ronzo is offline
Old 03-12-2010 | 12:33 PM
  #33729
Josh Keller is offline
Old 03-12-2010 | 03:00 PM
  #33730
spring71's Avatar
Smile
First prizes for TQ Grand Opening Race arrived from Team Associated.
Please Pre Sign up before the race, it will help me and racers for the best race event.
We will have a race on Saturday, tomorrow open at 10am, race at 3pm
Come on bring your 1/12s and let's race ...
Thanks Team Associated for supporting TQ RC RACING.
spring71 is offline
Old 03-12-2010 | 03:11 PM
  #33731
YR4Dude's Avatar
Who will be doing the annoucing at the Grand Opening Race?
YR4Dude is offline
Old 03-12-2010 | 05:55 PM
  #33732
kk4hg's Avatar
Default Sensor Cables
I'm new to this aspect of the hobby and need some help sourcing a sensor cable. I am trying to connect the LRP Vector X12 8.5 turn motor to the Novak Havoc 1S ESC. Any recommendations? I don't know the length yet because the car has not been built (12R5). I suspect somewhere between 4-6 inches. Are all sensor cables like connected so that they will work with any motor/ESC combination? Is there a standard for this?
kk4hg is offline
Old 03-12-2010 | 06:01 PM
  #33733
buffalobill989's Avatar
http://tqracing.com/sensor.htm
i think they are all the same. heres what i use
some of the best. very flexible. i use these and his wire to
buffalobill989 is offline
Old 03-12-2010 | 06:10 PM
  #33734
carcrazy699's Avatar
hey guys thinking of running a 12th scale. i have the tekin rs esc and was woundering if i stil need to get that smart boost from novak to run
carcrazy699 is offline
Old 03-12-2010 | 06:51 PM
  #33735
W.E.D.Jim's Avatar
stical, I replied to all the pms, thank you for your interest!
lmk
...Jim
W.E.D.
www.wedjim.com
