-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
Mark506 03-10-2010 01:26 PM
A flat servo over a angled servo will produce what....? A little more Camber gain, and a bit of a different ackerman feel?
ronzo 03-10-2010 04:18 PM
gen 12xl ?
i have gen xl i ran on carpet. how will it work on asphalt or do i need a Tbar car and witch one?
thnaks ronzo
CypressMidWest 03-10-2010 05:24 PM
Mark, Generally the steering feel is more immediate off-center with a flat servo. Servo flat set-ups also have a lot more bump-steer than angled set-ups. The bump-steer actually adds mid-corner steering, but can make the car a little inconsistent on bumpy tracks. Pulfer has been running servo flat, I've been running angled. It's a personal preference thing. Try it and see what you think.
dumper 03-10-2010 05:45 PM
thnaks ronzo
The Gen XL will work great on asphalt. Depending on how well prepped the track is, you might need to go one step stiffer on front spring, and step softer on the side springs and the center spring.
avs 03-10-2010 07:39 PM
that's interesting, i have been struggling with a very high bite indoor asphalt track. is this the situation you meant would benefit from stiffer front and softer rear?
i was going stiffer and stiffer front and rear to get more linear grip. what would you suggest with the gen XL layout?
W.E.D.Jim 03-11-2010 07:17 PM
In case any of you are interested in a custom painted 1/12th scale body, this one just came available today. :)
http://img37.imageshack.us/img37/8492/wed031110016.jpg
http://img72.imageshack.us/img72/4854/wed031110018.jpg
...Jim
W.E.D.
Get Faster Gear
www.wedjim.com
stical 03-11-2010 11:31 PM
...Jim
W.E.D.
Get Faster Gear
www.wedjim.com
PM sent
ronzo 03-12-2010 08:57 AM
dumper do you have a starting set up for asphalt?
Josh Keller 03-12-2010 12:33 PM
spring71 03-12-2010 03:00 PM
First prizes for TQ Grand Opening Race arrived from Team Associated.
Please Pre Sign up before the race, it will help me and racers for the best race event.
We will have a race on Saturday, tomorrow open at 10am, race at 3pm
Come on bring your 1/12s and let's race ...:nod:
Thanks Team Associated for supporting TQ RC RACING.
http://www.tqrcracing.com/forum/file...associated.jpg
YR4Dude 03-12-2010 03:11 PM
Who will be doing the annoucing at the Grand Opening Race?
kk4hg 03-12-2010 05:55 PM
Sensor Cables
I'm new to this aspect of the hobby and need some help sourcing a sensor cable. I am trying to connect the LRP Vector X12 8.5 turn motor to the Novak Havoc 1S ESC. Any recommendations? I don't know the length yet because the car has not been built (12R5). I suspect somewhere between 4-6 inches. Are all sensor cables like connected so that they will work with any motor/ESC combination? Is there a standard for this?
buffalobill989 03-12-2010 06:01 PM
http://tqracing.com/sensor.htm
i think they are all the same. heres what i use
some of the best. very flexible. i use these and his wire to :D
carcrazy699 03-12-2010 06:10 PM
hey guys thinking of running a 12th scale. i have the tekin rs esc and was woundering if i stil need to get that smart boost from novak to run
W.E.D.Jim 03-12-2010 06:51 PM
stical, I replied to all the pms, thank you for your interest!
lmk
...Jim
W.E.D.
www.wedjim.com
