Originally Posted by PDX-Spike
(Post 6739818)
NEVER DISCHARGE A LIPO BATTERY!
I said, "Never Discharge a LiPo Battery"
Originally Posted by 1fastdude
(Post 6746264)
Why not?
I have been using LiPo batteries for three years in my cars which I race on a regular basis. I have never discharged these batteries and have not noticed any degradation by using them without discharge. I have not heard of or read about any benefit gained by discharging LiPo betteries. If I am misinformed about discharging LiPo batteries, please let me know. |
(Post 6747353)
Primarily, LiPo batteries are volatile and if used improperly may result in fire, personal injury and damage to property. I have been using LiPo batteries for three years in my cars which I race on a regular basis. I have never discharged these batteries and have not noticed any degradation by using them without discharge. I have not heard of or read about any benefit gained by discharging LiPo betteries. If I am misinformed about discharging LiPo batteries, please let me know. I think what the poster was trying to say is to NEVER discharge below 3V/cell. You can cycle LiPo packs just like any other but it usually is unnecessary. Balance charge thenm and you're fine. Just use some common sense and a compatible charger. |
The nice thing about 12th scale lipos - no balancing needed... Single cell has it's advantages.
REEDY 4600 LIPO 3.7v
Hello I have a question about charging this battery on a ICE charge Does anyone know how I can charge it at say 6 amps? I can never get the pack to a full charge. Last time I charged it at home it gave an error about time exceeded and stopped. So I would like to know how I can increase the amps. thanks, Satish |
(Post 6746264)
Why not?
Originally Posted by AreCee
(Post 6747572)
Don't you discharge them everytime you plug them into your car to use?
I think what the poster was trying to say is to NEVER discharge below 3V/cell. You can cycle LiPo packs just like any other but it usually is unnecessary. Balance charge thenm and you're fine. Just use some common sense and a compatible charger. So, when is it necessary/beneficial/required to use an appropriate LiPo discharger to drop the voltage to 3 volts? |
Originally Posted by Satish
(Post 6747807)
It is suggested to only charge at 1C, so in this case is would be 4.6A. The CC/CV charging profile raises the charging current to the configured charge current, holds it there until the pack reaches 4.2 v (for 1s), then holds the voltage constant and slowly drops the current until the battery is "full". This usually happens when the current is approximately 0.10 A. It takes a significant amount of time for the current to drop to 0.10 A after the pack reaches the max voltage. As long as you have the time, let it charge all the way.
(Post 6747807)
Hello I have a question about charging this battery on a ICE charge Does anyone know how I can charge it at say 6 amps? I can never get the pack to a full charge. Last time I charged it at home it gave an error about time exceeded and stopped. So I would like to know how I can increase the amps. thanks, Satish Hope I explained it right. |
Satish. Sounds like your charger is hitting a mAh limit or a time limit. I am not familiar with the ICE but there should be an option to increase the mA limit or time limit. If you are charging at 3A lets say, then some chargers will stop charging when 3000mAh has been reached. The charger thinks the battery is 100% full even though the voltage is not to 4.2V.
ice setup
i use a couple of ices' to charge my batteries, charge them at 1c(4.6 amps in your case.) and at the bottom of the menu options set your charge capacity to 110%, that should get your batteries fully charged, and will help you avoid those messy overcharging messes.
Greetings
Satich- Hope all is well.
AreCee- Merrrrrrry XMas buddy! Good seeing you/hanging at the IHobby. I'll prolly never be a crawler guy, but you guys did an impressive job. Hope to rub some paint before winters over. How's the Grex treating you? Very impressive tools those guys have. |
Just want to say a big thanks to all who pm'd and posted. THink I got this thing down pat.
Only thing setting i am getting mixed comments about is with the Max Charged Capacity setting at the bottom. Some say 50% some 100, 110. So far I am not having any problems. I check the temp of the lipo regularly, and all is well. Currently it is set at 6000, charging at 6amps with 50% max charge capacity. Thanks again everyone, and have a great holiday :) s |
Crank that max capacity up to 100% I don't get why they have over 100%? If it's 100%, thats all you get.Don't bother tempting, it'll tell you it's hot. Simultaniously, it'll ignite.:flaming: These settings are working well for me.
Originally Posted by TeamCarnage
(Post 6749333)
AreCee- Merrrrrrry XMas buddy! Good seeing you/hanging at the IHobby. I'll prolly never be a crawler guy, but you guys did an impressive job. Hope to rub some paint before winters over. How's the Grex treating you? Very impressive tools those guys have. I found electric 1/8 off-road and love it, got a Hot Bodies Ve8/D8 Tekno Frankenstein but it works. Going to LH Sunday to play in the dirt and Jtec on the first for 1/12. I still can't race up north for particular reasons I have. Miss big guy, always has been fun racing a gentleman like you. |
| All times are GMT -7. It is currently 11:47 AM. |
