Originally Posted by SlowerOne
(Post 7024985)
Same set-up as Trev, no problems at all. Servo speed is good, no drop-off in any electronics during a race. Thanks to complete brain fade on my part, it worked even when I dumped the LiPo pack below 3v because I forgot to charge the LiPo! :blush:
No connection to RC Dynamics, except a love of their product! HTH :) |
Originally Posted by whynot
(Post 7025099)
Do you guys with the reciever pack have to charger them after each race? is there a pack that will last a whole day of racing? What is a life pack why would you use this instead of a lipo pack?
LiFe is a different battery type that is lower voltage, 6.6 volts so no worries about over juicing the electronics. |
(Post 7025099)
Approximately how many milleamps will be drawn from a LiFe receiver pack in an 8 minute run with a 13.5 and Tekin RS, and, what is the largest capacity LiFe receiver pack that will fit a 1/12th? Not looking to switch unless I can run three heats without having to recharge. |
Remember with LiFe, you don't have to charge them at 1c. You can charge one up in just a few minutes.
Do you need a special charger to charge the LiFe battery?
Originally Posted by PDX-Spike
(Post 7025160)
I have almost the same question.
Originally Posted by RacinJ
(Post 7026762)
GOOD GRIEF! I started surfing around to look at the RC Dynamics booster and found the site. Scrolled to the bottom and found the price . . . ~33 pounds=~80 dollars US.:eek:
Originally Posted by andrewdoherty
(Post 7027118)
Still a bit to pay, but if its well designed, as it seems to be, and it works when you need it to, which would be always, its worth it. Too bad the Novak booster is designed around an IC that clips out at 3.3volts. I like the 3 amp output capability, but it is useless since it drops out and causes receiver issues. Had thought of making my own when 1s first hit the track, may have to again. :nod: |
(Post 7027118)
(Post 7027118)
I have lots of pounds I want to change at that rate:sneaky: |
1 Attachment(s)
Originally Posted by reynard55
(Post 7027668)
Can you tell me where you get that exchange rate from?
Originally Posted by oldrcr
(Post 7027429)
actually, 33. British pounds would exchange to 51. US dollars. :)
Still a bit to pay, but if its well designed, as it seems to be, and it works when you need it to, which would be always, its worth it. Too bad the Novak booster is designed around an IC that clips out at 3.3volts. I like the 3 amp output capability, but it is useless since it drops out and causes receiver issues. Had thought of making my own when 1s first hit the track, may have to again. :nod: I copied the page. I dunno why it comes up like that . . . ?:confused: |
http://www.xe.com Is the best one to use for calculating exchange rates.
New to 1/12
Just got an Associated 12r5.1 and a 1s lipo, now I need to get a motor\esc combo for it. What do you guys recommend? I'd like to spend less than $200 if possible. Thanks.
Originally Posted by argyle43
(Post 7027986)
Free Shipping |
| All times are GMT -7. It is currently 05:02 AM. |
