Battery ???
Is there a definate advantage in using a 1s 3.7 lipo w/booster or w/receiver pack over a 2s 7.4 lipo saddle pack in the Gen XL or in general for racing? Is the weight difference significant? Is there a difference in performance?
Originally Posted by svines1972
(Post 7029182)
However I don't know of any rules that allow that in 12th scale at this time ? 4 round cells have been replaced by 1S lipo, this is the current status of 12th scale in the US of A. |
Thanks Redbull. So the saddle pack lipos are 1s 3.7? Any noticeable difference between the single pack and the saddle pack?
Yes the 1/12th specific saddle is 3.7 voltage. Technically speaking the stick pack will have a slight advantage because of less resistance. But the difference is small enough that most drivers won't be able to tell. Unless you have a t-plate car then there is no reason to use a saddle pack.
Originally Posted by SlowerOne
(Post 7026918)
Then don't switch, use the RC Dynamics booster instead...
So small and lightweight it isn't even taped down. Just floats above the receiver! |
UK 12th National is underway at Maritime Raceway. Check out Thomas Ridgley's Blog for news and results
Originally Posted by radio_car_racer
(Post 7031282)
Go Elliot Harper!!! |
I was woundering if someone could help me out. Im running a speedmerchant rev5 and when i get back on the throtle comming out of a corner the rear wants to come around other than that the car is great what could i do to stop that from happening .
Thanks Ryan |
has the diff been rebuilt?? a gritty/notchy diff will cause all sorts of handling traits
I find that a lack of droop in the pod will cause the same thing.
Change diff balls and add more droop.+
Body with good room.?
I'm building my new Associated 12R5.1 (Great car!)
And now i need a body with good room, because i use a tall ESC. I'm using a LRP SXX TC Spec, and i have a Protoform Speed12 body. But it's not tall enough for the ESC to fit under it. So i need another body. We are talking 2-3 millimeters more height under the body, where the ESC is located. What about the Parma EE1, CRC Black Art Audi R8C Lightweight or Black Art Pacemaker R10 LMP Lightweight? Does these body have more room? They look a little bigger. And how does they perform? The tracks i'm driving are very complex tracks with lots of corners. Regards.. Frank Olesen Danish 1/12 newbie :D |
Try a Protoform AMR-12. It has a bit more room on the sides.
Okay Thanks :)
How is the handling of that body? Is it good in corners and still stable on the straights? |
Yes
| All times are GMT -7. It is currently 08:10 PM. |
