-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
1fastdude 11-10-2010 10:33 AM
Originally Posted by Hyper_Mike (Post 8191876)
Just a quick tire question for the 12th scale gurus on this thread! If I'm looking for more general rotation through a corner is it better to go to a softer tire on the front or a harder compound on the rear? Under what conditions would you favour one approach over the other?
Thanks in advance for your ideas!
Cheers,
Mike
YES, or you could change your set-up a little bit. You may just want to ask Ian Ruggles (lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program)
Hyper_Mike 11-10-2010 10:39 AM
?????....nevermind, sorry to have bothered you.
1fastdude 11-10-2010 10:44 AM
What I mean is:
You can use a softer tire up front --- Sometimes you will get loose through the run.
You can use a harder tire in the rear --- Typically not the way to go.
You can change your set-up --- Thinner lube in the dampner tubes, softer front springs, harder top spring, more camber in the front, etc, etc, etc.
odpurple 11-10-2010 01:43 PM
Originally Posted by TrevCoult (Post 8190385)
There's nothing wrong with the Queen's English :p
Though SlowerOne speaks it far more accurately than me :D
Trev
Nothing wrong with it at all. It's just that over here so many people only speak Bush's American ;)
SlowerOne 11-10-2010 01:52 PM
Originally Posted by Slapmaster6000 (Post 8188258)
I still say, if you want to reduce your diff maintenance and increase your reliability; run a thrust bearing. If you are bent on having the silkiest diff and don't mind keeping a constant eye on it; use the cone washer.
Brian
There speaks someone who knows, and to whom one should listen carefully. Thanks, Brian.
Originally Posted by avs (Post 8189583)
what do you mean by ball race? i presume thrust race means a thrust bearing (like splapmaster), but 'ball race' means what? are you referring to the thrust bearing with races replaced with flat washers?
Originally Posted by odpurple (Post 8189619)
He means using the ball bearing in the outer part of the hub as the thrust, the way most of the cars like 12R5 etc come. He's just hard to understand sometimes because he speaks the Queen's english :lol:
You guys, what are you like! :lol: :lol:
Originally Posted by avs (Post 8189661)
ah-so! thank you for translating, Egnlish is my second language.
As George Bernard Shaw said "England and America are two great nations separated by a common language" :D
Trev
Cor blimey guv, what a gent you are!! For those in the land of the five time zones, that needs to be said by Dick Van Dyke using that crazy cockney accent he failed to pull off in the film Mary Poppins - horrendous!!
When we say we are "mad about a flat", we mean we are very keen on a new apartment and you mean you are :flaming: mad about having a nail in your tyre (sorry, tire!). OK, I'll get my coat... :lol:
inconceivable 11-10-2010 02:13 PM
I realize this question will be dependent upon a number of factors, however I'm looking for a better general understanding of how a 1/12 scale should react overall (on carpet). Specifically, I feel that I have to wait a little too long in most corners to get back on throttle. Many setup and tire changes have had various affects on this (good and bad), however it just always seems this way. I've been racing 1/12 scale for the past year or two so I know what my car can do, however I'm not totally sure what it "should" do. As a general rule of thumb is a well setup car able to get on power in the turns early and often ? Maybe another way to say this is, if the car were perfect could you almost drive full throttle the entire track ? I do realize this would not be the fastest way around the track, but hope you get my point. Or, am I just expecting too much from the car ? This could be the case as it is by far the most fun car I've driven over the years. Thanks !
axle182 11-10-2010 02:31 PM
Different cars will demand different driving styles to get the best, but rule of thumb, higher cornering speeds will give faster laps. Always be weary of the pay off..... ie getting on the throttle harder may feel faster, but if it puts you on the wrong line for the next corner etc, it will not be faster.
It sounds like you have an on power push going on? First question would be front tires.....
Remember to be weary of the pay off of having more on power steering. Usually for me, it means more off power steering too, and usually that means mine starts to hook on the front tires on entry. I like a car that pushes a little and slowly make small changes to get just enough corner grip. Reason.... the car can then make really nice FAST arcs through a corner, and my car exits SO much faster than the cars who take much tighter 'point to point' driving lines. This has other positive effects, lower temps, more room to gear up etc etc etc.
Not sure if that answered your question or not, but reply with some more info and we will see what we can suggest.
pmes 11-10-2010 02:35 PM
Originally Posted by CanyonCarverR1 (Post 8191459)
Does anybody have a good source for LiFe Rx packs? >200mAh would be good.
Forget LiFe, check this one out:
http://www.horizonhobby.com/Products...ProdID=HBZ1017
wingman2 11-10-2010 02:46 PM
Hi guys, there seems to be quite alot of talk regarding missed laps due to transponder's not sending out a decent signal due to low voltage. I reckon that this could be overcome by placing the timing loop in a better position, ie, not where cars are travelling under full, or almost full acceleration. If the loop is at a place where the throttle is not open (going into a slower corner for example), then the full voltage will be available to power the transponder and hopefully no more missed laps! Only an idea chaps!!
CypressMidWest 11-10-2010 05:22 PM
Cheers,
Mike
I'm of the mindset that rotation is generally a result of set-up at the rear of the car.
If the track has decent bite, sometimes a harder tire will actually limit rotation. In most instances a Yellow rear will offer more rotation, and also more forward bite than a grey rear. At the Halloween Classic this year, I started on Yellow rears. The car rotated well, but had an on-power push at corner exit. I switched to Grey rears, and lost a bit of rotation, but the car gained exit steering because of the reduction in forward bite. Consequently the car was smoother and easier to drive.
Thinner tube lube, stiffer shock spring, and stiffer side springs can also increase rotation. My first choice is usually to reduce dampening, next I'll change the spring. If these two options don't give me the feel I'm looking for, I'd then try different tires.
If the new tires get the car "out of the carpet" then the goal has been met. If not I'll then change to stiffer side springs.
This is all assuming that you have enough front-grip to carry the car through the corner. If the car turns-in well, and washes out mid-corner,(which would obviously limit rotation), either the front springs are too stiff, or there's not enough camber.
PDX-Spike 11-10-2010 11:16 PM
Originally Posted by pmes (Post 8192742)
Are you absolutely certain that this product is better than a LiFe? If so, tell us why it is better.
PHI/BMI racer 11-11-2010 02:57 AM
not best idea... you will need a step down voltage module... servo cannot take more then 6V however with LiFe 6.6V is OK because they test the LiFe for the servo... 7.4V will cook it... Have seen it...
PHI/BMI racer 11-11-2010 02:58 AM
Agreed, but rather not take a chance and good luck getting ppl to change things at their tracks...
:tire::tire::tire:
PHI/BMI racer 11-11-2010 03:09 AM
Ok so here is a question from me...
We been very limited up to now on which LiPo batteries we can use for 1/12th... Well not anymore so... for 1/12th Modified what would be better a higher mAh like 5600 - 6000 with a lower C rating like 50C or a lower mAh like 5400 with 60 - 65 C rating.... Can't find a battery with both and I am guessing higher mAh is better for runtime... Any thoughts
:tire::tire::tire:
avs 11-11-2010 06:42 AM
with a 2s receiver pack you will need to reduce voltage to 6, providing more components to fail. i don't know about all ESC's but tekin specifically warns against feeding the RS with 7volts from the receiver. KO electronics is good for 2s voltage but they seem to be the exception.
(my experience with voltage reducers have not been good. i have 2 for 2 failed. i had one fail at the start of the back straight on my gas car. if it had failed 1.5 seconds later it would have been very ugly. the lipo pack in my transmitter had a voltage reducer built in, which died while stored between races)
